Tie Rod?
Old Dec 13, 2008 | 02:41 PM
YorkPaVette's Avatar
YorkPaVette
5th Gear
Default Tie Rod?
I was driving my car slowly out of my hood and my drivers wheel started pulling. I can not see anything wrong behind the wheel but, truly I cant see behind the wheel very well. The wheel does not turn left or right when the other does. My question is. Does this sound like a tie rod and are there any ideas on cost.
Old Dec 13, 2008 | 03:52 PM
byronhunter's Avatar
byronhunter
[QUOTE=YorkPaVette;1568184417] The wheel does not turn left or right when the other does. QUOTE]
Get under it, time for a visual inspection!!!!!!!!
Old Dec 13, 2008 | 06:54 PM
vettesrgt8's Avatar
vettesrgt8
Jack the car up and turn the wheel/tire. If it doesn't turn then make sure the emergency brake is not on. Remove the tire and wheel if it turns and inspect.
Old Dec 13, 2008 | 07:56 PM
lucky131969's Avatar
lucky131969
What does the emergency brake have to do with the steering?
Old Dec 13, 2008 | 09:12 PM
byronhunter
I wonder?
Old Dec 13, 2008 | 10:56 PM
LoneStarFRC's Avatar
LoneStarFRC
I'm thinking steering rack and/or ball joint(s) needs a good look.
Old Dec 14, 2008 | 11:39 AM
mikeam's Avatar
mikeam
FYI - just had my tie-rods replaced, right side was worn out and failed NC inspection. It's expensive, parts are $142 (Dealer) each but you can get them from Gene Culley, a vendor on this forum for around $108. You'll also have to have a wheel alignment. Due to the timing, I had to have the stealership do it
Old Dec 14, 2008 | 05:16 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
sounds like a broken rack.
To Tie Rod?
