Shift light hook up under the hood
Old Dec 13, 2008 | 06:18 PM
GreyGT-C's Avatar
GreyGT-C
Default Shift light hook up under the hood
I did a search on here but all i've found so far is the wiring under the dash board "how-to's". Anyone point me towards the switched power wire and the tach signal wire under the hood? I'm on dial-up right now (i know, i know... hard to believe anyone is still on dial-up) and it takes fooorrrrrreeeevvvvvveeeerrrr to sift thru all the write-ups to see which one has the right info for me at this speed.
Thanks in advance...
Old Dec 13, 2008 | 07:50 PM
HWY HNTR's Avatar
HWY HNTR
Positive coil wire if your shiftlight is programmable to run on 1cyl setting.
Old Dec 13, 2008 | 10:42 PM
GreyGT-C's Avatar
GreyGT-C
I don't know if it's programmable to run on 1 cyl or not.. I'll have to go out to the garage tomorrow and check. It's a raptor shiftlight.
Now,Anyone know where a switched power wire is under the hood?
thanks!!
Old Dec 13, 2008 | 11:00 PM
byronhunter's Avatar
byronhunter
Fuse #16, under hood fuse block.
Pink wire on any coil.
That is 2 of them,, is that enough? This is fron '02 service manual.
BH
Old Dec 13, 2008 | 11:08 PM
GreyGT-C's Avatar
GreyGT-C
You guys ROCK!!!!!!!!
To Shift light hook up under the hood
