hypertech III ,question before ordering
Old Jan 17, 2002 | 11:09 AM
maninblack's Avatar
maninblack
Default hypertech III ,question before ordering
I have an 02 MN6 with basic mods(xr-1,k&n filter) what would i expect horsepowerwise by doing the hIII programing ?,would it be a waste of money.
thz in advance for input :cool:
Old Jan 17, 2002 | 12:07 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
Default Re: hypertech III ,question before ordering (maninblack)
I have one and if I had to do it again I would not spend the money. I think horespower gains are minimal if at all. It does change shift points,fan relays and will bump up the rev limiter. Your choice :confused: :confused:
Old Jan 17, 2002 | 12:19 PM
B. Stewart's Avatar
B. Stewart
I like it because of the rev limiter, and the ability to adjust the firmness of your shifts. I have used all of its functions and like the results.
Old Jan 17, 2002 | 01:22 PM
SwissVette_Joe's Avatar
SwissVette_Joe
maninblack,
IF you drive an A4, then you may consider to purchase one. As for the CORVETTE M/Y 2002, the new HPP3 is not already released (??). But certainly, other fellow CF-Members could confirm this situation or give more informations and news.
I myself am pretty satisfied with the working of the HPP3-software in my M/Y99 A4. There are many advantages in the download of the software, as eg "power-tuning", fueltrim/spark advance, shift firmness, shift points, rpm rev-limiter, different gas-quality ratings, speedo-calibration, gear-ratos, top-speed limiter setting, Fan kick-in earlier, 50 state legal. Until actual, I had not the littlest problems with pinging, knock-retard or whatsoever.
Best is, you can always "go back-download" to genuine stock PCM-setting within about 10', if necessary (Dealer's visit/maintenance). As for their claimed plus 20HP, I am not shure until I can see it during my next DYNO-session during March - I shall keep you posted.
This foreseen run shall cover all my inbetween realized enhancements around the LS1 (bolt-ons), to check results with and without the HPP3. Wish me good luck!
Old Jan 17, 2002 | 10:19 PM
maninblack's Avatar
maninblack
Default Re: hypertech III ,question before ordering (SwissVette_Joe)
thz all for your input.I think i will pass on it at this moment as I am still waiting
for my 3.73 :cool:
Old Jan 17, 2002 | 10:55 PM
2FAST4U's Avatar
2FAST4U
I wouldn't get it for an MN6! I have it an I'm glad I do...but I'll also have an A4. It is basically worthless from a purely HP gain standpoint. I used it for bumping up rev limiter and manage A4 shift points after I bought my Halltech intake. I also used it to set the temp lower 180 degree.
I will use it for the rear end upgrade to 3.42 to reprogram the PCM for an accurate speedo and shift.
[Modified by 2FAST4U, 8:55 PM 1/17/2002]
Old Jan 17, 2002 | 11:44 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Can I borrow one to bump up my rev limiter?
Old Jan 18, 2002 | 12:43 AM
newberd's Avatar
newberd
Default Re: hypertech III ,question before ordering (wallstAL)
I have one I use on my 98 A4. The programer will not allow it to be used on more than one vehicle at a time. Their way of copy protection I guess. I have three 98s (Coup A4, Vert A4 & Coup M6) and I can only use it on one at a time. The programer id's the car before programing begins. If I want to use it on one of the others, I must unload it from the first vehicle. So you can't borrow one just to bump up the rev limiter and return it the owner. :mad
Old Jan 18, 2002 | 08:31 AM
geekracer's Avatar
geekracer
It's handy for the simple stuff like fan temp changes. Plus you can go back to stock tuning if you need to.
Old Jan 18, 2002 | 10:42 AM
C5XTASY's Avatar
C5XTASY
maninblack,Until actual, I had not the littlest problems with pinging, knock-retard or whatsoever.
What did you mean to say here? I ask because I have a Hypertech III also, but have not tried the power tuning part that modifies timing and A/F ratio yet. I am extremely happy with the rest of it. Thanks!
Ed
Old Jan 18, 2002 | 01:23 PM
SwissVette_Joe
Default Re: hypertech III ,question before ordering (C5XTASY)
Ed,
may I ask you to excuse my wording, as english/us-english is not my mother's language. So, must I think having misled you (?), however this was not my intention. :blueangel:
The meaning of my reply to CF-Brother "maninblack" was, that in reference to all my mod's done to the intake section (MTI RamAir...now that's kind of brute cold-air....//GMS-MAFS//BPP VORTEX AirBridge plus Silicone-Coupler), I may have to expect a certain risk of PINGING or KNOCKING/KNOCK-RETARD due to leaning-out the engine. All this under the condition the PCM could NOT compensate the heavily increased amount of the new airflow by adjusting the engine's fuel-trim towards more rich.
Now, if you then go with the HPP3's so-called "powertuning", you eventually increase even more the "risk", by further increasing any lean condition, b/c this part of the software further advances fueltrim AND sparkadvance. So in the end, you might find you with lean mixture AND early/advanced ignition re to one of your pistons which travels already upwards to his ignition stroke [readers ps forgive me, I'm neither a certified expert as many others of you, nor calling me CF-member "kewlbrz" (are you reading?). Just trying to set up my words for the process].
As already mentioned in my first post, I shall check the influence of my HPP3 (mainly HP gain) during my next DYNO-session, agenda in March. One of the reasons I did NOT encounter negative side-effects at all with download of HPP3's software could be find in the fact, that our street-gas here around is of 98ROZ-standard (premium super). Overall, this car pulls real strong and absolutely willing from any position of the accelerator, having even not touched the upper end until now.
Could I reply to your uncertainty? If YES, then BRAVO and I am happy. I shall promise some improvement in formulating...there is always some hope.... :smash:
Joe
[Modified by SwissVette_Joe, 6:28 PM 1/18/2002]
[Modified by SwissVette_Joe, 6:29 PM 1/18/2002]
Old Jan 18, 2002 | 02:10 PM
jawski's Avatar
jawski
I was so-so with HPIII until I installed a MAFT, really woke up the car, see mods
But, I CAN'T GET NO satis-TRACTION :cry :D
Old Jan 19, 2002 | 03:26 AM
C5XTASY's Avatar
C5XTASY
Thanks, Joe.
Ed
Old Jan 19, 2002 | 03:53 AM
Superj's Avatar
Superj
Default Re: hypertech III ,question before ordering (2FAST4U)
I had a Hypertech for my Impala SS which was an automatic. There were some benefits there but I don't see it being much good for an M6 outside of fan temp and rev limiter. I guess you could also use it if you changed your gears or tire size.
To hypertech III ,question before ordering
