TPS disconnect from Computer
Old Dec 14, 2008 | 12:29 PM
"Uncle T"'s Avatar
"Uncle T"
Cruising
Default TPS disconnect from Computer
I recently put new wheels on a 2000 and the TPS were not a perfect fit so I decided to do without them. How do I disconnect this function from the computer so I stop getting the low pressure warning.
Thanks!
Old Dec 14, 2008 | 12:38 PM
dougbfresh's Avatar
dougbfresh
YOU don't, you need to find someone with a Tech II programmer to program it out. Probably CHEAPER to put the sensors in.
Old Dec 14, 2008 | 12:49 PM
Thickraybans's Avatar
Thickraybans
You may not be able to disable the TPS on a 2000, I think this is only possible on 2001 and newer.If you post this in the Scan & Tune section you might get a better answer.
Old Dec 14, 2008 | 01:50 PM
timemender's Avatar
timemender
Can NOT on 97-2000
Can on 2001 & up
Old Dec 14, 2008 | 02:50 PM
Bakersfield's Avatar
Bakersfield
If you still have the original sensors, I can rebuild them for you. Just drop me a PM if I can help.
Old Dec 14, 2008 | 03:04 PM
"Uncle T"'s Avatar
"Uncle T"
Cruising
Thanks everyone. I'll just live with it for the time being!
To TPS disconnect from Computer
