spec 3+ in 98 vette?
Old Dec 15, 2008 | 01:59 AM
-Fidanza-'s Avatar
-Fidanza-
Default spec 3+ in 98 vette?
Does anyone have this clutch, and how do you like it if so?? What are other good clutches rated at 850 lbft? and What flywheel are you guys using?
Old Dec 15, 2008 | 08:27 AM
JJS04's Avatar
JJS04
Cruise-In X Veteran
I have this clutch and have nothing good to say about it other than the fact that your left leg will grow. The harder that I run the better it seems to grab.
Old Dec 15, 2008 | 01:01 PM
HWY HNTR's Avatar
HWY HNTR
Zoom D2. tiny bit of chatter, light pedal feel, never sticks, holds a lot of power.
Old Dec 15, 2008 | 11:20 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
We have the 3+ clutch and the steel flywheel in our turbo Z06 shop car. It holds 740 ft-lbs with no problem.
Old Dec 16, 2008 | 12:42 AM
-Fidanza-'s Avatar
-Fidanza-
How is drivability?
Old Dec 16, 2008 | 11:42 AM
Drewstein's Avatar
Drewstein
I had the 3+ in my 640rwhp setup as a DD with not one issue. When I went with the 402 I put in a 3+ twin I liked it so much.
Old Dec 16, 2008 | 12:06 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
I have this clutch in my 427 D1sc 17lb boost and 150 nitrous and no problems. As advertised it will chatter til you have 500-700 miles and then just goes away, feels like stock to me. Cheers
Old Dec 16, 2008 | 07:20 PM
AMRAAM's Avatar
AMRAAM
I used the 3+ IN my 97. I like it alot. Not quite as smooth as stock, but pretty close. Pedal pressure is pretty close to stock as well. I am running about 545HP with a p1sc and holds fine for me.
To spec 3+ in 98 vette?
