driveline vibration questions
Old Dec 18, 2008 | 05:20 AM
twotonedZ's Avatar
twotonedZ
Default driveline vibration questions
01 Z06..
#1) When the car is in Neutral, clutch pedal released, and the engine is revved to 3000rpm, is the propeller shaft rotating?
#2) With the car still in Neutral, clutch pedal depressed, and the engine revved to 3000rpm, is the propeller shaft rotating?
#3) With the car in any gear, and the clutch pedal depressed, and the engine revved to 3000rpm, is the propeller shaft rotating?
Thanks for your help.
