engine has a miss
Old Dec 27, 2008 | 05:51 PM
dougbfresh's Avatar
dougbfresh
If you have the intake and valley cover off, why can't you get to the lifters?????????? Your question is weirdly worded-not sure what you asking exactly.
Old Dec 27, 2008 | 06:16 PM
jaybar's Avatar
jaybar
I am asking a number of things.
1. Yellow springs worth installing over after market.
2. When doing a leak down test how much time do I allow for each cylinder to get a reading or is it instantaneous?
3. I looked it up in the shop manual and I see that the lifters in their guides are installed in a slot in the block which is covered by the head. So I am assuming I will not be able to see the cam and lifters through the "top". I would love to be wrong on that one.
Old Dec 27, 2008 | 06:51 PM
dougbfresh's Avatar
dougbfresh
If your not changing cam/heads, stock springs are fine, leakdown is more about differences between cylinders (unless you get fast leakdown in all cylinders), your really checking leaks past the rings and valves. Watching and listening are important, leaks thoug the valves will make noise in the intake/exhaust. Leaks past rings will make noise in the crankcase. Compression and leakdown tests together give you a better picture of engine health.
Your correct on the lifters, the head has to come off I believe.
Old Dec 29, 2008 | 09:28 PM
jaybar's Avatar
jaybar
Well, I did not know if you could see the lifters and cam with the valley cover removed. I searched several sites and finally came up with a picture of the lifter galley, or valley as it called on an LSx. It seems most of the cam and lifters can not be seen. It looks like maybe the #1, #7,and #8 can be partially seen, but I could not tell from the camera angle to what extent they could be evaluated. So I am going to save myself the trouble of removing the manifold and valley cover.
I borrowed a leak down tester (single gage) from a friend and will try it out over the coming 4 day weekend.
Old Dec 30, 2008 | 12:45 PM
Fasthotrod's Avatar
Fasthotrod
You have to pull the heads to replace the lifters.
We just did a set in my friend's 2005 C6 LS2. (Along with a few other mods... rockers, cam, supercharger, intercooler, etc... )
http://forums.corvetteforum.com/1568125284-post891.html
http://forums.corvetteforum.com/1568200685-post122.html
http://forums.corvetteforum.com/1568238736-post249.html
If it was me and I was this far into the motor, I would replace the lifters, pushrods and springs.
LS1. LS2. LS6, LS7 lifters: $130
http://www.lingenfelter.com/store/12499225.html
Comp Cams LS1, LS2 stock length pushrods: $110
http://speed-eng.com/store/comp-chro...en-p-7601.html
LS6 valve springs: $53
http://www.lingenfelter.com/store/12499224.html
New spring retainers would be a good idea while you are at it...
At this point, you aren't too far off from a cam swap...
Good luck.
Mark
Old Feb 24, 2009 | 01:04 PM
jaybar's Avatar
jaybar
The last two months have been busy. The following thread is my write up on the installation of the items suggested in this thread.
check out
http://forums.corvetteforum.com/c5-t...cker-arms.html
Thanks to all who have made suggestion and given advice.
Jay B
