MSD Window switch with N2O
Old Jan 18, 2002 | 09:54 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default MSD Window switch with N2O
Those of you running the bottle, where did you wire your wondow switch to? Fuel pressure safty switch? Where did you get the tach signal from? #10 pin on the ECU?
Old Jan 18, 2002 | 10:49 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: MSD Window switch with N2O (ICULUKN-C5)
help
Old Jan 18, 2002 | 11:22 AM
C5Noir's Avatar
C5Noir
For the wiring, follow this diagram:
The tach wire is on the PCM, the plug closest to the passenger seat of the car on PIN #10.
To MSD Window switch with N2O
