car radio
Old Dec 27, 2008 | 10:07 AM
jeanC5's Avatar
jeanC5
Default car radio
help!!!! my car radio is "loc"but i have not the code, what's to be done?
Jean of FRANCE
Old Dec 27, 2008 | 10:26 AM
Bakersfield's Avatar
Bakersfield
Do a search in this section for "radio lock" as well as the C5 General section under audio/electronics and you will probably find your answer there. Good luck.
Old Dec 27, 2008 | 10:51 AM
jeanC5's Avatar
jeanC5
OK thank you!!!!
Old Dec 27, 2008 | 12:01 PM
Daddyrama31's Avatar
Daddyrama31
Default Unlock your radio
1. Turn th ignition ON (The radio displays LOC)
2. Hold down the Radio Presets 2 and 3 for six seconds.
3. The radio display changes from LOC to a three-digit number. Write this number down. Don't take forever, fifteen seconds max before the next step.
4. Press the AM/FM button
5. The radio display changes to another three-digit number. Write this number to the right of the first one.
6. You now have a six-digit number, the first three digits are from Step 3 and the last three digits are from Step 5.
7. Call 1 800 537 5140.
8. Press 1 then # (pound). You'll hear "Invalid Code, try again".
9. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by *.
10 Enter the number from Step 6 then * (Star)
11. Listen to the four-digit number and write it down. It will be repeated twice.
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from Step 11
14 Press the AM/FM button. The radio display changes to SEC.
Old Dec 27, 2008 | 01:24 PM
jeanC5's Avatar
jeanC5
thank you very much!!!
Old Dec 28, 2008 | 12:15 PM
jeanC5's Avatar
jeanC5
HELLO!
I succeeded has to leave the 6 figures(382393)but i do not arrive has to telephone.
Somebody can please do it for me and give me 4 figures for the code?
HELP HELP!!!
Old Dec 28, 2008 | 01:09 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by jeanC5
HELLO!
HELP HELP!!!
The above 139010 does not work
Old Dec 28, 2008 | 01:21 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I called the number. Your 4 digit code is 1261. See if that works!
jeff
Old Dec 28, 2008 | 01:22 PM
JeffC5's Avatar
JeffC5
Try 206053 instead of the 139010 and it should work. The 139010 must be outdated.
Old Dec 28, 2008 | 01:47 PM
jeanC5's Avatar
jeanC5
waow!!fantastic!! merci!thank you very much!!
j'essaye demain!!
Old Dec 28, 2008 | 09:58 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
My understanding is that code is a dealer identifier.
Since most dealerships charge the customer for this service the numbers probably get changed when it becomes known it is being widely circulated.
Old Dec 29, 2008 | 08:31 AM
jeanC5's Avatar
jeanC5
hello has all!!
that is there!!the car radio functions!
thank you very much "JeffC5"for the phone call!
i can listen the Cd of ZZ TOP !!!
To car radio
