Still trying to understand the LSA difference from cam to cam. Some say a 112 will require fly-cutting on a G5X3 and a 114 won't. So I thought anything under 114 would require cutting. The MS4 is 111 right?
I have a 2003 Stock Coupe A4 with stock LS1 heads. LG Long tubes, X-Pipe, Stingers.
Does this CAM require fly cutting?
MS4
230/230 .609/.604 111lsa ?
I would say that fly cutting the pistons (with the stock heads) for this cam isn't necessary...however it is a pretty big cam so you are going to want to check to be sure. One thing you are going to want to do is replace the stall converter. I recently swapped my cam for a 228/230 .571/.573 112. I didn't have to fly cut the pistons and I'm running Dart Pro1 heads, which have much less valve drop than stock heads. I did replace the converter but I also ran it with the stock converter for about a week. It is possible to get it to idle with my cam but the performance (low end) was pretty poor. Went with the Yank SS3600.
BTW - I'm running 3.42 gears as well. That cam would suck with 2.73s and stock converter.
Guess I need to do some more research.
3:42
dr phil (roadrebel)
im running 112lsa on my ms4- was told lil easier to tune/streetable
