Oil pressure questions
Old Jan 1, 2009 | 09:08 PM
David426's Avatar
David426
Default Oil pressure questions
My oil pressure reads 39lbs at idle and up to 80psi at 4800rpm.. This is on my 02 z06. 44k miles. I know about the crappy sending units.. I had one replaced at 40k on my 99 c5.. Usually when they go out they peg 80psi and on the DIC pressure reads even higher.. like around 130psi.. Any suggestions... I just had a mobil 1 5w-30 oil change with a mobil 1 oil filter..
Old Jan 2, 2009 | 09:28 AM
David426's Avatar
David426
any ideas
Old Jan 2, 2009 | 09:37 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by David426
any ideas
Compare the reading with a mechanical gauge.
There's a plug in the front of the block, where you can check oil pressure at the pump.
To Oil pressure questions
