PCV Valve Help
Old Jan 2, 2009 | 12:57 PM
trickflow's Avatar
trickflow
Default PCV Valve Help
The hose that holds the PCV valve on my LS1 is cracked from heat. Is there any way to repair this and is the ground wire really needed. Thanks
Old Jan 2, 2009 | 01:59 PM
lucky131969's Avatar
lucky131969
Not being able to see what specific part you are talking about, hard to say. I suppose you could try to section in a piece of hose, but I would replace the damaged part. There is no ground on the pcv valve. The clip and wire that screws to the block is for heat transfer, not for an electrical ground.
Old Jan 2, 2009 | 02:13 PM
Patches's Avatar
Patches
Doesn't the rubber housing come with a new PCV valve? I would buy a new one - the new design is supposed to be an improvement anyway.
Old Jan 2, 2009 | 02:18 PM
VinnyT's Avatar
VinnyT
I had the same problem. If you are talking about the rubber part that houses the PCV, you'll need to purchase the whole PCV hose assembly. I lucked out to get a new one on (that auction site) for $60. A dealer will charge $105.
Heres the thread:
http://forums.corvetteforum.com/c5-g...asap-help.html
Old Jan 2, 2009 | 02:29 PM
Patches's Avatar
Patches
Bummer.
Old Jan 2, 2009 | 02:34 PM
trickflow's Avatar
trickflow
Heres the thread:
yep that's the part.
Old Jan 2, 2009 | 02:38 PM
lucky131969
The part number for the assembly is: 12590632.
$62.71 from GMPartsDirect.com
To PCV Valve Help
