Fidanza twin installed
Old Jan 2, 2009 | 06:25 PM
LDB C5's Avatar
LDB C5
Default Fidanza twin installed
I just finished up the installation of a Fidanze twin disc with an aluminum flywheel. I have a couple of questions:
1.) The first couple of starts from a stop the engagement point was all the way at the top of the pedal and it slipped quite a lot. After about 6 or 7 more starts, it seems to have settled down and stopped slipping. Is this normal for a new clutch? Also the engagement point is not quite where I would like it to be. Can this be adjusted? Will it change by itself as the clutch gets broken in?
2.) I don't know whether or not this is related, but my speedometer no longer works. As far as I can tell it gets its feed from the individual wheel speed sensors. Is this correct? Any other idaes?
As far as the feel of the clutch, I have to say I am pretty impressed so far. The pedal is firmer than stock, but not bad at all. I will need a retune as a result of the reduction in rotating mass. The engine revs MUCH faster which means that the revs fall off just as fast; it wants to stall. I will post up results and thought after I have had a chance to put a few more miles on it.
TIA
Len
Old Jan 2, 2009 | 06:28 PM
lucky131969's Avatar
lucky131969
TIA
Len
Len,
You might have forgotten to hook up the VSS (vehicle speed sensor) on top of the differential. Worse case, something got damaged on the reinstall.
Old Jan 2, 2009 | 06:35 PM
lucky131969
The connector in this pic is for the VSS.
http://www.flickr.com/photos/1545929...25488/sizes/l/
Old Jan 2, 2009 | 06:36 PM
LDB C5's Avatar
LDB C5
I though I did, but you never know I had the drive train in and out twice (stupid issue with the slave feed line). I will check the connector tomorrow... I thought the feed for the speedo came from the wheel sensors; but I have been known to be wrong before.
Thanks!
Old Jan 2, 2009 | 06:38 PM
lucky131969
Thanks!
The wheel sensors are for the AH & ABS.
Old Jan 2, 2009 | 06:43 PM
LDB C5's Avatar
LDB C5
Pretty sure I hooked it up. might not have been all the weay in and got knocked off when I was playing with the exhaust. If the input for the speedo is taken from the diff; I will need to change the setting for the gear ratio in my tune; correct?
Old Jan 2, 2009 | 06:44 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If the VSS is disconnected, it could cause a lot of other tune-related issues, since some PCM parameters are based on speed (or at least moving/not moving)
Are you getting a P0500?.
Old Jan 2, 2009 | 06:47 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
It's read from the output shaft side (reads axle speed(, so gear ratio is irrelevant.
Old Jan 2, 2009 | 06:49 PM
LDB C5's Avatar
LDB C5
Good point; I didn't check for codes No CEL so far. The car runs OK except for the issue fo stalling which could be related to the lack of VSS. Would that effect getting into reverse as well? I have never had issues with reverse until tonight.
Thanks for all the insight. I will be back under the car tomorrow
Old Jan 2, 2009 | 06:50 PM
lucky131969
http://www.flickr.com/photos/1545929...27395/sizes/l/
http://www.flickr.com/photos/1545929...63252/sizes/l/
http://www.flickr.com/photos/1545929...27575/sizes/l/
Old Jan 2, 2009 | 07:28 PM
SWEBLD's Avatar
SWEBLD
TIA
Len
Hi Len !
1) I went through this last summer with the same clutch. Very hard to notice the slip at start but slipping got worse and finaly i had to replace it(with an RPS). Actually there was a "dip" in power at 6000rpm that my tuner could not explain but who supected the clutch ?? Fidanza claims there are clutch slaves out there with wrong specifications(to "tall"). But since MY SLAVE barely can release my RPS clutch now i suspect that some of the fidanza dual discs are somewhat faulty. Mine will be shipped back to Fidanza for a refund. The new RPS cost me 3000$ installed
Old Jan 2, 2009 | 11:11 PM
LDB C5's Avatar
LDB C5
The slippage was obvoius the first couple of starts; and then started to go away. I cleaned everything with brake cleaner but all I can figure is that it takes a few starts to break the "glaze" on the new discs and flywheel.
Anyone else have any ideas?
Old Jan 3, 2009 | 07:52 AM
vsocks1's Avatar
vsocks1
Which clutch did you install, the Fidanza 7.6?
Old Jan 3, 2009 | 09:52 AM
LDB C5's Avatar
LDB C5
It is the twin disc; but without the segmented discs. I don't recall the model number. I will see if it is on the box when I go back out to the garage.
Old Jan 3, 2009 | 10:56 AM
slow ride's Avatar
slow ride
Do you have some sort of shim behind the slave? Sounds like the slave is pushing against the clutch spring even when released causing less clamp load on the disks. Having the clutch release at the top of travel tells you that there is not much(if any) free play between the slave and the clutch pressure plate diaphragm spring.
If you don't have a shim behind the slave then there is not much you can do. Most corvette problems are due to the release point being to close to the floor which poor bleading could cause and/or adding a shim could help, but in your case it's just the opposite.
Old Jan 3, 2009 | 03:57 PM
LDB C5's Avatar
LDB C5
Speedometer issue fixed I missed the VSS plug on top of the diff
Slippage issues gone
Engagement point still needs to be better understood, but I can live with it. I will call Fidanza Monday AM.
Thanks to all those who offered advice and suggestions!!
Old Jan 3, 2009 | 04:06 PM
OKsweetrides's Avatar
OKsweetrides
Report back on how it turns out and if it's normal an all! Inquiring minds want to know this clutch turns out!
To Fidanza twin installed
Old Jan 3, 2009 | 06:03 PM
SWEBLD's Avatar
SWEBLD
If the pedal still engages right at the top you have been warned. Fidanza admits that the pedal engagement right at the top is an issue due to some slaves having to long rods(oem vs aftermarket thing). Ask for Wayne if you call them. It took me +1100km to realize that the the "high pedal problem" wasn´t going to cure itself, neither the slip... And i´m really sorry since the Fidanza twin felt like a GREAT CLUTCH !
Old Jan 5, 2009 | 02:11 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Glad everthing worked out smooth with the differential install. I am still not a very good fan of the clutch that you chose.
In my personal experience, if you forget to hook up the VSS plug, you will have problems going into reverse and the speedometer will not work. How are you liking your new 3.90s?
By the way, I am in your hometown right about now for my sister's wedding
Enjoy and be safe Len!
Old Jan 5, 2009 | 09:27 AM
LDB C5's Avatar
LDB C5
Hi Nouman; The gears are everything you said they were except for one little thing ........ They are hard on cold tires Sent you a PM
