C5 auto guys with mods in here
Use your savings for "noise pollution" tickets and rear tires.
Best wishes.
Glen
my goal is anywhere from 430 to 470 and 500 is not a must number. i just want to make it something that i am going to enjoy.
the car is pretty much stock and well taken care of.
when a torque converter is installed- does it still drive like an auto? do I have to hold a certain button or something?
Also, I heard that a supercharger is expensive on these for parts and labor- true?
I just want to see what direction most of the auto guys went- thanks
If you go with an aggressive cam you will also need a stall converter and then you might as well change out the gears at the same time.
Why are you chasing HP numbers? Do you race at the drag strip or street? Are you simply wanting to change the sound of your corvette with the cam?
I do not want a cam that makes the car unenjoyable- but i do like the sound of a cam. not sure what cam would be perfect to keep it enjoyable. I do not race, but do want something that will keep up with most street cars. i do want to get the most out of the automatic, but i guess it will require me to get a built tranny with a converter. I would be happy with a nice sounding vette that has some bite and know that i have those extra horses that might be needed
You would really love changing gears to 3.42 or 3.73 perhaps a 2800 vig stall.
If you go with a high stall you will end up with a slush box and probably not what you want.
If you just want a mild cam then perhaps englend green "ninja cam" out of houston will be a good choice as it does not require a stall converter.
If you have not had a tune done after the addition of headers that should be done and a for sure change of your gears.
I would put those 2 at the top of your list for instant seat of the pants change.
Do you plan to do the work yourself, or have a performance shop do the work?
If you do it yourself, you can buy budget or used parts, but of course, buyer beware of budget or used parts. I've been burned in the past with some used items, so choose carefully.
To get to your goals for a Head/Cam car you should have a bunch of supporting mods.
Cold Air Intake: Vararam $300
Headers: American Racing $1800 (LG Pros $2000)
Torque Converter: Yank SS3200/SS3600 $775
Gear Upgrade: GM Z06 3.42 carrier $1300
Exhaust Upgrade: Borla Stingers $800 (Corsa/GHL $1100)
So by using all top shelf components, your at ~$5000, just for parts. Having all that installed brings it closer to ~$6500.
That $7K just got eaten up real fast, believe me, I know because above is exactly what I've done with my car.
Now, you'll pay at least $1500 for a cam install, more like $2500 if you get better springs, etc. Plus you'll have to pay for tuning, which is usually in the ball park of $300-$500. Good heads cost $$$$ (Trickflow/AFR), and then you'll probably want a FAST intake. List never stops.
Of course this post will be flame bait since everybody and thier grandmom will post up how you can do it cheaper. Of course you can. That's not the point. This is what it takes for quality components for someone who only knows how to open a checkbook. If your handy, and willing to do some work, yes you can do it for a little bit less.
And you can even skip some steps. You don't NEED headers with a cam, but to get the most benefit, you do. You don't need gears, hell.....you don't even NEED a TC after a cam install, but I'm here to tell you, you'll end up hating your car without one.
On the other end of the spectrum, a supercharging kit will get you around 100hp gain, even without the supporting mods. All in what you want to do.
Can meet up with a lot of other corvette guys for more advice and check out what they have done.
thats all you'll need,
good luck.
so definitely the gears and tc. i might just look for a used supercharger and be done with it.
as much as i would like to do heads and cam, it looks like the sc is the way to go since i am not a nitrous guy.
