Lowering – Leaf to Control Arm Distance
Old Jan 6, 2009 | 10:03 PM
Fire 22's Avatar
Fire 22
Default Lowering – Leaf to Control Arm Distance
In the process of lowering so I did the back first and the back bolts have the same number of threads showing after turning each bolt the same number of turns (I am not lowering all the way). In the front before doing anything I noticed that the drivers side bolt sticks past the leaf about 1/4” further than the passenger side. So I measured the distance from the end (top side) of the leaf to the base of the bottom arm and there is about a 5/16” difference with the passenger side having the greater distance. I turned the passenger side (lowered) bolt the same number of turns as I did the back and now with out turning the drivers side bolt, the measurements on both sides from the leaf to the base of the bottom arm are the same. I think I will not adjust the drivers side at this point, am I correct?
