the pressure plate of my oz700 died...it has no pressure and the clutch slips like crazy! sooo does anyone know where i can get it rebuilt or even if it can be rebuilt?
well i called jarrod and he said if its a manufacturing defect he will warranty it and said to email him to get the address to send it to so i did and its been 2 days and no email back
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
I am talking to Jarrod now regarding my OZ700 Z grip tearing up after 900 street miles, two street tire passes and one drag radial pass. It took me four times to get through on the phone today. He is very busy but from all accounts is a fair person to deal with. I will update as we go.
I am having the same problem. Mine almost never has any pressure behind it and sometimes grinds between shifts because its not fully dis-engaging?
I thought it may have been a hydrolic problem that could be fixed with an adjustable master cylinder but it may be worth sending back to get looked at?
Have you dropped the inspection plate and checked the air gap when the clutch is disengaged ? Air gap should be .030 or so.
How's the pedal feel ?
No I havent checked the gap.
On my morning drives, the pedal is mushy but randomly, under various circumstances, Ill get in it throughout the day and the pedal feels strong and you can feel the clutch grabbing hard by the vibrating/pulsating coming from the clutch.
Its like and on/off switch here lately
Sounds like air in the slave, do you have a remote bleeder ? Or maybe a bad throw out bearing.
