Depo non pop up projecter light install issues
Old Jan 7, 2009 | 05:09 PM
mark b's Avatar
mark b
Default Depo non pop up projecter light install issues
I just got my depos installed by a top tuner shop. They are not evenly installed (the gaps between the lights and fender/bumber/hood is uneven. The amount of space is not even. The tuner shop that installed them explained that because of the bracket and bolt positions, one side of the light has to be bolted closer to the fender/bumber leaving a big gap on the other side. They tried to make each side have the exact same gap spacing so at least both sides look identical but the spacing is off.
Has anyone who has had these lights installed encountered the same problem and do you have a solution? did you use shims between the bolts to push the lights into a more centered position between the fender/bumber/hood? from a distance you cant tell but when you look close up you can see the gaps.
I cant believe these companies that make these type of lights for the
C5 cant get it right after all these yrs..
Old Jan 7, 2009 | 09:51 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You obviously do not have a lot of experience with body work.
There are slight variations between all cars and that is why most items (body parts) have some adjustability.
Without some pictures of your problem it's to tell you what might help the problem.
The lights you have, have brackets underneath that are bolted to the rails. You may have to take out the lights and lengthen the or widen the adjustment slots on the brakets to achieve a better fit. You can also use some larger washers to move (shim) the brackets from side to side. Try to figure out you much the gap is off from each side to figure out how thick of a washer to use.
Old Jan 8, 2009 | 02:36 AM
grnmchn's Avatar
grnmchn
I read that by opening up the stock holes in the depo brackets you can get a lot more play. I did that on mine and used a washer or two and got them OK. I think unless you are willing to take the front clip off, adjust the lights and reinstall and repeat until you get it right they won't be perfect. It looked like a PITA to me so I installed them by removing the front turn signal and the side skirts and fenderwell in front of the tires. Even that way it took me the better part of a day and I work on lots of cars.
Good luck but I would just learn to live with it, I don't even notice the gaps on mine anymore. A shop in my area would probably charge $500 to get them perfect. Do some searches cuz very few people have them installed perfectly, uneven gaps are very comon.
Old Jan 8, 2009 | 10:52 AM
comecorrect's Avatar
comecorrect
Like the others have said you can enlarge the holes and add washers to get them to fit much better. Good luck!
MIKE
Old Jan 8, 2009 | 11:26 AM
mark b's Avatar
mark b
Thanks for the replies.. I had a well known tuner place install them not a body shop...they obviously did not shim anything or try to get the spacing perfect, they just installed them and just that was a p.i.t.a..
I guess I have to live with it for now until I have a body shop work on correcting the gaps. At least both sides look exactly the same.
Are there any special tools(nuts,bolts,shims, whatever) that you used to get them perfect so I can pass on the knowledge to my body shop?
thanks.
Old Jan 8, 2009 | 12:17 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
thanks.
Don't know why you would pay anyone to install them as it is a pretty simple task, just time consuming.
1.) The easiest way to work on them is to drive up or jack up the front of the car.
2.)Remove the front side spoliers (left & Rright) 7mm screw caps and then remove the front coverings from the fascia.
3.) Take some 3M painters tape and put it around the outer edges of the headlight opening so that you don't scratch up the paint.
4.) Get a straight ruler and measure the gaps on each side and top to bottom. Add the two together and then divide by two to get the proper spacing needed on each side. Once you have figure out which side you want to adjust and measure the current gap and figure out if you need some spacers (washers) to correct. You may have to slightly bend the brackets.
4.) Diconnect the light power connector and then remove the bracket bolts or just lossen them up a bit. Use a drop light so that you can look at the brackets to see if you need to grind them some etc ...
Old Jan 8, 2009 | 12:52 PM
imflyinbiya's Avatar
imflyinbiya
LOVE mine, no real fitment problems at all. I did slot the brackets for the best results, which didn't take THAT long...
These with H7 HIDs = best mod to date.
Old Jan 8, 2009 | 01:05 PM
lucky131969's Avatar
lucky131969
I installed Specterwerks fixed headlights in a friends 2002. They were very time consuming. To add to the alignment issues, he had a tigershark front end, and a maggie hood.....so getting everything shimmed and aligned was fun. Just be patient, and take your time.
Old Jan 8, 2009 | 10:56 PM
zoomz's Avatar
zoomz
I installed my set yesterday .
I had a buddy watching the spacing on top while i tightened the 2 bolts and 2 nuts without taking off any thing but the bottom cover panel and l/r rubber air dams .
We had them both in in an hour .
Its is very time consuming to get the spacing exact but it can be done .
Now i just need to adjust the lights down out of the trees ,, lol
To Depo non pop up projecter light install issues
