I have mine off completely but don't remember how I did it. Wasn't real hard though, but then I have a Tigershark nose. I thought it was just about 8 bolts or so.
Drive it up on ramps or a couple 2x12s. Clean it with a brush from under the front. Blast from back side. I made a long probe for my compressor with some soft copper tubing. Hit it with water after if you want. No real need to take it all apart.
Well I got it reasonably clean and then had the hardest time re-attaching the condensor back to the radiator. In the process I pull out the two plastic bayonete fasteners that hold the front shroud on. No way to reconnect them without a total dis-assembly. It does not seem imperative that these be connected as they just hod things together a bit better.
Really the only thing holding the condensor and radiator in the correct position in the top cover and its four bolts. I never realized just how delicately that is all put together.
Anyway, bottom line, take your time, understand your limitations and take your time!
When I cleaned mine, I didn't remove the condensor or move it at all. Took the top cover off only. To clean though, the first time, I used an air wand that I bought from Harbor Freight for like $4.95. Its got the perfect bend in it to go between the radiator and the condensor to blow garbage back out towards the front. Now where I live, I don't have easy access to my compressor, so I fabricated the same thing but for water. It worked just fine.
I agree with the other guys here - no need to remove everything. Just do it from the bottom and you can get 90% of the stuff out. I do this once a year and usually get a small handful of sand out. When I first did it on my 35k miles coupe I got much more then that. I also used the long wand sprayer for a couple bucks.
