Blinking turn signal....
Old Jan 8, 2009 | 10:57 AM
Irish Whiskey's Avatar
Irish Whiskey
Default Blinking turn signal....
Right front turn signal will not continue to function properly. Not the bulb - it has been replaced. Open up the fascia and loosen the bulb and socket- then light is not on and the turn signal clicks very fast. Take bulb out-replace it with some electrical goo - it works. Go down the road for a couple of days and then it stops working again.
Is it the socket? Do I just "snip" the wires and get a new socket at the dealership? Thanks.
Old Jan 8, 2009 | 06:24 PM
Irish Whiskey
ttt
Old Jan 9, 2009 | 11:52 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Sure sounds like you isolated it to the socket. Try cycling the hazard switch too.
Old Jan 9, 2009 | 02:31 PM
szach13's Avatar
szach13
same thing happen to me changed the socket and worked fine.you can see that the inside of my socket was burned though
To Blinking turn signal....
