Brake lines
Old Jan 11, 2009 | 07:59 AM
csexton's Avatar
csexton
Default Brake lines
Going to send my Calipers off to be powder-coated. What is the best way to seal off the brake line to keep the fluid from draining out.
Thanks,
Chuck
Old Jan 11, 2009 | 08:25 AM
LoneStarFRC's Avatar
LoneStarFRC
I think I would just drain them as best you can then stuff some paper toweling inside the hose hole and put a piece of tape over it to secure and pack inside a plastic baggy.
HTH
Old Jan 11, 2009 | 01:24 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Not sure I'd use anything that might leave lint behind to stop up the orifice, but I'm weird that way.... Might try a small rubber "cork"???
Old Jan 11, 2009 | 03:12 PM
c5blkvetteguy's Avatar
c5blkvetteguy
A buddy of mine used a small nut and bolt with metal washers and rubber washers. So it went: bolt,metal washer,rubber washer,brake line,rubber washer,metal washer then nut. I have not done this, but he did and it worked.
To Brake lines
