stock x pipe and cats?
Old Jan 11, 2009 | 07:23 PM
cgm12mgc's Avatar
cgm12mgc
Default stock x pipe and cats?
are these the stock x pipes and cats?
Old Jan 11, 2009 | 07:46 PM
brinx's Avatar
brinx
3rd Gear
In my search for aftermarket exhaust systems your cats look stock but the x-pipe looks aftermarket. In looking at details about the stock cross-over it is a straight pipe welded between the pipes and has a small hole that is drilled into each pipe. That is why they recommend changing the x-pipe. If I can find where I had come across the pics of a stock x-pipe I will post it then.
Old Jan 11, 2009 | 07:51 PM
cgm12mgc's Avatar
cgm12mgc
sounds good, i am looking to get rid of my cats, is it helpfull to just gut the stock ones? or should i have a new pipe welded into their place?
Old Jan 11, 2009 | 07:54 PM
cgm12mgc's Avatar
cgm12mgc
well i should say... i know welding a pipe is best, is there anything i should worry about if i gut the cat?
Old Jan 11, 2009 | 09:09 PM
C5XTASY's Avatar
C5XTASY
Your car came stock with an H-pipe. That is an aftermarket X-pipe that was installed. You can gut the cats but most get a very smelly exhaust when that is done.
Ed
Old Jan 11, 2009 | 10:05 PM
itzza427's Avatar
itzza427
Ed
Almost everyone complains about smell after going catless.I'd save them in case you want to go back,,,,plus they are worth a few hundred at salvage/recyclers!! That is why there is such an epidemic of cat theft at public lots and SUVs. Thieves jump under wit a reciprocating saw and rip them oun in a few seconds and get $150 to $250 for them. Kinda silly to just destroy them!!
Old Jan 11, 2009 | 10:13 PM
cgm12mgc's Avatar
cgm12mgc
good to know! ill just hook up a new pipe with that "H" pipe i see that the exhaust open at the connector i am going to just run a pipe to connect the x pipe to my headers, sound like it will work?
Old Jan 11, 2009 | 11:57 PM
C5XTASY's Avatar
C5XTASY
Not exactly sure what you're trying to say here, but I believe you're thinking about just removing the cats and installing a straight piece of pipe on each side in place of each converter. Be aware that you will not gain a whole lot, performance-wise, from this mod, except a louder exhaust, which is just fine if that's what you want.
Ed
Old Jan 12, 2009 | 09:27 AM
B-Vette's Avatar
B-Vette
You could go with after market Hi-flow cats, I'd probably do that then go with nothing.
P.S. That X-pipe looks like a Magnaflow that you have installed.
Old Jan 12, 2009 | 10:26 AM
jrose7004's Avatar
jrose7004
Your car came stock with a H-Pipe so the X-Pipe is aftermarket.
To stock x pipe and cats?
