MGW Shifter C5 or C6
Old Jan 12, 2009 | 03:20 AM
PR1AWRet's Avatar
PR1AWRet
Default MGW Shifter C5 or C6
Made the decision to go with the MGW shifter. I have a 2004 Z06. Should I stick with the one for the C5 or is there an advantage using the one for a C6?
Old Jan 12, 2009 | 06:50 AM
FloridaFRC's Avatar
FloridaFRC
I believe they are the same. the c6 just comes with a different handle to use the stock c6 ****. the c5 handle is threaded for the c5 ****.
Old Jan 12, 2009 | 08:22 AM
WKMCD's Avatar
WKMCD
Correct.
Old Jan 12, 2009 | 09:08 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
The C5 and C6 use the same shifter base and lower handle. The C5 upper handle is straight and threaded for the C5 type ****. The C6 upper handle is offset about an inch and is set up for the C6 style ****. I have heard that you can order the C6 handle threaded as well. If I had it to do over I would order the C6 handle threaded which would move the handle to the rear. Either way you go, I'm sure you'll love the MGW.
Old Jan 12, 2009 | 12:51 PM
ysb02's Avatar
ysb02
The shifter I got from MGW is offset in that there's a straight piece about 4-6" high then another piece that bolts onto it and is offset about an inch that the ball screws onto. It's not straight up like I've seen in pictures. Is this the C5 or C6 shifter?
Old Jan 12, 2009 | 01:46 PM
Mark C5's Avatar
Mark C5
That is the C6 upper handle. It will work fine in the C5, actually provides a better location IMO.
Old Jan 13, 2009 | 02:06 AM
PR1AWRet's Avatar
PR1AWRet
Went with the MGW C6 shifter and the C6 race grip. Will post later on my thoughts.
Old Jan 13, 2009 | 09:06 AM
waddisme's Avatar
waddisme
Old Jan 19, 2009 | 02:06 PM
ysb02's Avatar
ysb02
That's what I was thinking. I have mine rotated nearly to the back but it allows 360 degrees of movement.
To MGW Shifter C5 or C6
