High Oil Pressure - Help Needed
Old Jan 12, 2009 | 09:01 AM
LO PHAT's Avatar
LO PHAT
Default High Oil Pressure - Help Needed
Driving into work today I noticed that my '98 coupe's oil pressure gauge was buried to the right at 80 psi. I scrolled through the DIC and saw that the pressure was 128 psi. For the remainder of my 15 mile drive, the pressure remained between 126 psi and 130 psi.
This can't really be a normal operating condition, can it? Isn't normal psi around 40 psi (making my car's pressure nearly three times normal!)?
I need to drive home today after work. Am I risking damage to the engine? What might be causing the issue?
LO PHAT
Old Jan 12, 2009 | 09:06 AM
slothy's Avatar
slothy
sounds like your oil pressure switch took a crap, look at the sticky up top.
Old Jan 12, 2009 | 09:11 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by LO PHAT
"Am I risking damage to the engine."
Probably no.
"What might be causing the issue?"
It's usually caused by a failed oil pressure sensor.
Read the sticky at the top of this page. Lots of info. there.
Old Jan 12, 2009 | 12:52 PM
black98c5's Avatar
black98c5
Originally Posted by 8VETTE7
with both previous responses. Look at the stickey titled Oil Pressure Sender Relocate. It's got info about the sender failing and the various ways to replace because it is a little less that straight forward to access the sender for service.
Old Jan 12, 2009 | 09:49 PM
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
I suggest the Buick oil pressure switch convertion
Old Jan 12, 2009 | 11:36 PM
rws.1's Avatar
rws.1
Many of us just replace it... If done correctly there are no issues.
Here is a link to the best DIY replacement on the Forum
http://forums.corvetteforum.com/c5-t...y-vectorz.html
Old Jan 13, 2009 | 08:49 AM
Quicksilver Vert 01
They're now making brass Chevy sensors that have the correct metric threads. The Buick sensor has NPT threads, and requires a threaded adapter for use.
BWD S4202 from Advance Auto Parts, and also other Parts America stores, is a direct fit brass sensor.
Old Jan 13, 2009 | 10:01 AM
togan's Avatar
togan
I agree
Old Jan 13, 2009 | 10:54 AM
k0ts's Avatar
k0ts
Another option
http://forums.corvetteforum.com/c5-t...elocate-4.html
Old Jan 13, 2009 | 05:07 PM
Quicksilver Vert 01
Originally Posted by k0ts
Ouch!
Old Jan 13, 2009 | 06:03 PM
lucky131969's Avatar
lucky131969
Originally Posted by Quicksilver Vert 01
Ouch!
Yep, the duct tape is classic.
Old Jan 13, 2009 | 06:10 PM
mobman's Avatar
mobman
I agree the duct tape is kinda cheezy and not the way I went but I think this is the easiest way to relocate.
Old Jan 13, 2009 | 09:06 PM
waterdog's Avatar
waterdog
ecklers makes a relocation kit for this
Old Jan 13, 2009 | 11:15 PM
LO PHAT's Avatar
LO PHAT
I just wanted to say thanks to all of you who replied.
What a PITA this is going to be! I spent a few hours both yesterday and today researching this issue and reading all of the threads here. I am not looking forward to this project, and I'm not yet sure what way I'll go with the repair (cut the hole, relocate with hose, or move to front of block). Each option seems to have its pros and cons.
As a car guy I'm not really ok with the idea of driving my car with no oil pressure reading. That said, I really would prefer to not be without my car right now (it is my daily driver). How long do you figure I'll have before the sensor starts leaking oil (or will it at all)?
Thanks again,
LO PHAT
Old Jan 13, 2009 | 11:38 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I went with the chop a hole method. I thought about it cause I didn't want to cut a hole in the car. But I did and it's simple. Can't see it. Doesn't bother me now. 30 minute job or less depending on how hard the wipers want to be in removing themselves.
Old Jan 14, 2009 | 07:54 AM
dougbfresh's Avatar
dougbfresh
The manifold removal isn't that bad but if you cut a hole, just make a NEAT plate to cover the hole and rivet it on then you'll have good access for the future. There are a couple of other things back there that having access to are NICE (like the vacuum supply for inside the car).
Old Jan 14, 2009 | 08:15 AM
Quicksilver Vert 01
If it's not leaking any oil now, your only immediate concern is not knowing what the engine oil pressure is. I wouldn't be comfortable with driving that way that either.
If space allows it, I'm thinking about installing a small 0-100 psi guage
in the front oil pressure tapping on the engine.
I've decided to leave the sensor in the stock location, hoping the new brass sensor will prove to be a more durable replacement.
To High Oil Pressure - Help Needed
