Speedometer Question
Old Jan 20, 2002 | 12:58 PM
Mr. C's 5's Avatar
Mr. C's 5
Default Speedometer Question
Does anyone know how the VSS translates drive shaft rpm into mph and if it can be adjusted to compensate for diffferent tire diameters? - C.
Old Jan 20, 2002 | 01:36 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Speedometer Question (Mr. C's 5)
I believe the VSS reads MPH directly from the rearend, not the drive shaft (actually the torque tunnel.) If you change either rear end ratio or tire size you need to adjust the PCM, not the VSS. A custom PCM program can be done to correct it or you can use someing like a Hypertech to do it too. Good luck.
-Jeremy
Old Jan 20, 2002 | 02:29 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Speedometer Question (Godspeed)
Actually, not correct. The VSS reads the ring gear in the carrier... which does not change with rear end axle ratio upgrades. But, tire size changes will indeed cause a speedo error. The Hypertech can correct for this.
Best to call them with your specifics before ordering.
To Speedometer Question
