Tranny cooler and shift kit?
Old Jan 12, 2009 | 06:30 PM
Tonesc5's Avatar
Tonesc5
Default Tranny cooler and shift kit?
98 C5 has anybody installed either of the 2, someone told me it would be good for the life of the tranny (heavy duty shift kit and b and m tranny cooler?
any drawbacks >?
Any information will be greatly appreciated!
thanks tony
Old Jan 12, 2009 | 06:43 PM
aleadfoot's Avatar
aleadfoot
Cooler is a great addition and will prolong trans life. Shift kit isnt needed tune the PCM with an experienced technician and your shifting will be incredible. Eventually upgrade trans components pump clutch planetary the A4 is fantastic
Old Jan 13, 2009 | 07:46 AM
Tonesc5's Avatar
Tonesc5
Default does the c5 have a factory tranny cooler?
im yet to really get the car on a lift and look at it well
Old Jan 13, 2009 | 01:44 PM
MattB's Avatar
MattB
You can monitor the trans temps on the DIC. I'd only consider a cooler if you do have high temps, above 210 or so, or go to the track. Otherwise may be a waste of time. The over heating warning does not come on until after 250.
Shift kit, forget it. Even a mail order tune will make the A4 shift better.
Old Jan 13, 2009 | 01:58 PM
Dave Sweatt's Avatar
Dave Sweatt
And if you decide on a cooler be sure to plumb it to go through the B&M 1st, then through the one in the radiator. (B&M out to radiator in
) That way during cold weather the radiator cooler acts as a pre-warmer to keep the fluid from getting too cold.
To Tranny cooler and shift kit?
