stupid question about stock heads
Old Jan 13, 2009 | 12:20 AM
VidViper's Avatar
VidViper
Default stupid question about stock heads
OK, I see someone advertising several different LS1 heads for sale. 241? 893? I see that the earlier C5's had 893 heads and they have "center bolts" as opposed to the "side bolts" on the 241's. My question is, can I take the heads off a late model LS1 and put them on an early LS1? Or will the bolt holes be in the wrong place?
Old Jan 13, 2009 | 01:03 AM
KCvetteowner's Avatar
KCvetteowner
The heads are interchangeable. HOWEVER, the different valve covers (center bolt vs. perimeter bolt) also use a different coil pack mounting method. The perimeter bolt valve covers have each coil pack mounted directly to the valve cover. The center bolt valve covers use a bracket all the coil packs mount into and then that bracket is bolted onto the valve cover.
I'm not sure if the coil pack styles changed (could have) which would also mean your current coil packs probably would not mount the other way. I have read if you have the 853 casting ported it flows the same as the 241 heads. If it were me, I would go LS6 ported or aftermarket. Heads are expensive enough, don't do something you think you might redo later!!
Old Jan 13, 2009 | 03:43 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The 97-98 perimeter bolt heads were casting #806.
99-00 LS1's used 853 heads. These were of the centerbolt stule.
01-04 LS1s used 241 centerbolt heads.
01-04 Z06 LS6 used 243 heads.
As stated above, as far as bolting to the engine, all are interchangeable. To convert from perimeter to centerbolt heads, you will need to get centerbolt valve covers and coil pack brackets.
Old Jan 15, 2009 | 12:01 AM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I was told that a ported set of 853 heads could add 18-20 hp. No?
Old Jan 15, 2009 | 09:09 AM
E.jones's Avatar
E.jones
I have a set of ported and polished 853 castings but I dont know if I want to put them on if they are going to flow the same as the 241s castings that I already have on.
Old Jan 15, 2009 | 11:26 AM
gleds's Avatar
gleds
anyone know flow numbers? I have stock 806 heads.
To stupid question about stock heads
