C6Z06 Sway Bars for a C5Z
Old Jan 13, 2009 | 09:52 AM
p_dubya's Avatar
p_dubya
Default C6Z06 Sway Bars for a C5Z
Do they fit? I know the C6 Z51 sways are a direct replacement for the C5, i just want to make sure the Z06 sways will fit on my C5Z. I want to upgrade my suspension to C6Z shocks and C6 sways. i was going to go with the Z51 sways but I've got the opportunity to get some lightly used C6Z06 sways.
Is it recommended to replace the end links when replacing the sways?
Old Jan 13, 2009 | 11:02 AM
lionelhutz's Avatar
lionelhutz
Yes they fit.
Replace the end links if you think they are worn. The studs should be fairly tight in the sockets and not just flop around.
Peter
Old Jan 13, 2009 | 04:19 PM
spiral04's Avatar
spiral04
The Z06 shocks will work, but I believe the front sway is straight and there needs to be a dip in the bar to clear I believe the radiator? Someone else on the front sway??
Old Jan 14, 2009 | 02:38 PM
p_dubya's Avatar
p_dubya
I know the C6Z06 shocks will definetly work I just haven't heard of anybody installing the C6Z06 sway bar. I know some people have the C6 Z51 sway.
I just want to make sure the C6Z06 sway is a direct replacement for the C5Z.
Old Jan 14, 2009 | 02:56 PM
dmiz0420's Avatar
dmiz0420
C6Z front sway bar works on my C5, same shape just bigger
Old Jan 14, 2009 | 09:21 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
I believe the Z06 rear sway bar was an issue, but I don't know 100% sure.
Old Jan 15, 2009 | 12:02 AM
lionelhutz's Avatar
lionelhutz
There are a few guys here who claim they have them on their cars.
Code:
         front     rear
C6Z51    31mm      25.4mm
C6Z06    31mm      28mm
C5Z06    30mm      23.6mm
So, assume these are all made from about the same material and their resistance to twisting approximately scales with diameter. Then, looking at those diameters, you are basically adding a lot more rear swaybar to your car in proportion to the front swaybar change and will likely end up with over steer (ie the rear end will slide out first).
But then, what do I know, well besides the fact that over steer makes a car tricky to drive?
Peter
Old Jan 15, 2009 | 07:02 PM
Torch Red Tulsan's Avatar
Torch Red Tulsan
I have the C6 Z06 sways front and rear and '08 Z06 shocks. Didn't have any issues. If you're going with the shocks, I'd recommend making sure you get '08 Z06 shocks. They redesigned the rear shocks for '08 and I hear it was a vast improvement
Old Jan 15, 2009 | 11:15 PM
p_dubya's Avatar
p_dubya
Alright sounds good to me. Thanks for the input
Old Jan 16, 2009 | 03:29 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i run c6 z06 bars.
i also run 345/30/19 rear tires.
Old Jan 16, 2009 | 04:10 AM
lucky131969's Avatar
lucky131969
Originally Posted by jdmvette
i run c6 z06 bars.
Are those the 345's in the picture in your sig? If so, they sit under that widebody kit nice.
Old Jan 16, 2009 | 07:29 AM
jdmvette's Avatar
jdmvette
Night Owl for life
yeah that's them.
To C6Z06 Sway Bars for a C5Z
