Looking for info on DIY shock change.....
Old Jan 13, 2009 | 11:03 AM
Wingman2002Z06's Avatar
Wingman2002Z06
Default Looking for info on DIY shock change.....
A while back I found a link with pics and discription on how to change out the shocks on a C5. Dose anyone have that link available???
Thanks!!!
Old Jan 13, 2009 | 12:03 PM
Boulty1961's Avatar
Boulty1961
Default shock install help
I got this from the search tool.
The post said the the second one is good.
Good luck.
http://www.c5forum.com/diy/shocks.php
http://fuzzydiceracing.com/test.htm
Old Jan 13, 2009 | 01:31 PM
Gideon's_Test's Avatar
Gideon's_Test
I used the fuzzydiceracing instructions for my shock install...A tip: I used weedwhipper string instead of the zip ties to compress the schocks. Worked real nice. Did not have to double it up...
Old Jan 13, 2009 | 01:32 PM
MagRedConv's Avatar
MagRedConv
It's incredibly straightforward. Take off a wheel and all will be apparent.
Old Jan 13, 2009 | 02:52 PM
Wingman2002Z06
Really??? Thank you Mr. Obvious
I remember reading about a small issue with the instalation and couldnt remember what that issue was... The zip tie compression trick!
Thanks Gideon's_Test!!
Old Jan 13, 2009 | 04:16 PM
spiral04's Avatar
spiral04
Old Jan 13, 2009 | 05:03 PM
yellow94coupe's Avatar
yellow94coupe
Here's a tip I learned from replacing a friend's shocks recently. If the bottom bolt for the rear shock doesn't come out or go in really easily then jack up the a-arm just a little. Then it'll slide right in or out.
Old Jan 13, 2009 | 05:43 PM
Redneck Slim's Avatar
Redneck Slim
Active Streak: 90 Days
It's not hard IF you have the proper tools and equipment.
Front: With my Z51 springs (and likely with a Z06),I had to jack under the A-arm with a block of wood and also jack under the opposite rear tire to compress the front spring enough to install the shocks.
Rear: The bottom shock mounts torque to 162 lb-ft. I had to jack under the A-arm with a block of wood to install. To reattach the tie rods,torque to 15,then turn 160 degrees more,then torque to 33.
Old Jan 13, 2009 | 06:21 PM
gpotski's Avatar
gpotski
I followed the McRat method too, and it was exactly as shown.
It's very doable.
I used zip ties...worked fine.
Old Jan 13, 2009 | 07:53 PM
MagRedConv's Avatar
MagRedConv
Glad to help there.
Old Jan 13, 2009 | 09:50 PM
thetaxman's Avatar
thetaxman
why would you remove the tie rod ends ?
frankly if you need a how to on simple things like shocks , you may be better off having it done for you
Old Jan 13, 2009 | 11:43 PM
Redneck Slim
With most rear shocks,you have to undo the tie rod to maneuver the shock in or out.
Old Jan 14, 2009 | 02:26 AM
thetaxman's Avatar
thetaxman
you are kidding right ?
like I said.........
Old Jan 14, 2009 | 06:30 AM
vsocks1's Avatar
vsocks1
Not needed.
Old Jan 14, 2009 | 08:34 AM
Gideon's_Test
It is totally unnecessary to remove the tie rods when doing the shocks, but if I remember correctly, that's what the GM service manual suggests...(not sure why)..
Old Jan 14, 2009 | 09:58 AM
Redneck Slim
If you go to www.corvettefever.com and search,you can find pictorials on a C5 shock change.
To Looking for info on DIY shock change.....
