restoring chrome plated wheels - powerball
Old Jan 13, 2009 | 11:18 PM
aggiestckl's Avatar
aggiestckl
Default restoring chrome plated wheels - powerball
Whats the best method to get all the grime off? Powerball? What compound? What if i clean and cant get all the junk off?
Old Jan 14, 2009 | 12:30 AM
sami85L98's Avatar
sami85L98
Not trying to hijack but similer question.
I would like to polish the lip of rim, wondering if powerball will do that?
Old Jan 14, 2009 | 06:58 AM
dougbfresh's Avatar
dougbfresh
If the finish is pitted from brake dust through the plating-you AIN'T getting them clean.
Old Jan 14, 2009 | 07:19 AM
MagRedConv's Avatar
MagRedConv
Might want to check out the Car Care section.
Old Jan 14, 2009 | 09:28 PM
aggiestckl's Avatar
aggiestckl
Thanks D-Bag
Old Jan 14, 2009 | 10:08 PM
Bell's Avatar
Bell
I have used a product called NuFinish (chrome polish I got at Walmart) with my powerball. Worked pretty good, but the powerball will really sling the polish all over the place if you set the speed on your drill too high. Also, the powerball wouldn't get all the way into every area I wanted to get to, so still needed elbow grease. The main thing I didn't like about the powerball is that it is made out of soft foam and when you're doing thin edges (don't even have to be that sharp), the powerball fingers break off too easily - good for really only one use. Like me, you'll wind up with several of the metal studs it mounts to before you know it. Also, be careful not to apply so much pressure that the mounting flange contacts the wheel or you'll scratch it.
I've also used it on my wife's chrome plated plastic wheels - they cleaned up easily too, BUT with high speed and too much pressure applied, it's easy to accidentally burn through those thin plating finishes (ask me how I know).
Old Jan 14, 2009 | 10:10 PM
1slowFRC's Avatar
1slowFRC
Originally Posted by aggiestckl
Thanks D-Bag
Very Mature!
Old Jan 15, 2009 | 08:32 AM
LoneStarFRC's Avatar
LoneStarFRC
Thanks D-Bag
Originally Posted by 1slowFRC
Very Mature!
Needs to wise up.
To restoring chrome plated wheels - powerball
