TPMS Sensor Battery Replacement
Old Jan 15, 2009 | 11:20 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Default TPMS Sensor Battery Replacement
Is it possible to replace the battery in 2001-2004 tire pressure sensors? From what I've searched, it's only been done successfully on the older type 1997-2000 sensors.
I installed new sensors on my '01 along with my new tires and wheels last Spring, and I still have the original sensors and wheels.
Old Jan 15, 2009 | 11:23 AM
jrose7004's Avatar
jrose7004
Get a hold of forum member Corvette Don, I know he replaces them in the older units but he can answer your question about the newer ones.
Old Jan 15, 2009 | 11:25 AM
k0ts's Avatar
k0ts
I suspect they are nearly the same as the older design... I used a small bladed screwdriver and kept picking away until I found the battery.. It wasn't all that hard... The write up is good too...
I also suspect that finding the right battery and getting a few to install is more of a pain than just buying new sensors... 01s are cheap, relatively.. But go for it... You don't
have much to lose...
Old Jan 16, 2009 | 10:06 AM
Bakersfield's Avatar
Bakersfield
The circuit board and the battery inside the sensor can easily be damaged when soldering. Since the newer version sensors are fairly cheap, its just better to replace them.
FYI, I also rebuild the older version of sensors.
Old Jan 16, 2009 | 10:14 AM
Corvette Don's Avatar
Corvette Don
I have tried to rebuild the newer ones and have done it, however I need to get ahold of one of my buddies who have a 01+ vette to test them on, I figure in a couple more years ppl will start to need the newer sensors more than now and I plan to sell them rebuilt for under what they cost new, wont make much but if it saves a fellow corvette guy some money then im happy. I still do the older ones and I got 12 to do right now for a few customers but its not easy with a broken leg
Old Jan 16, 2009 | 10:28 AM
Quicksilver Vert 01
Thanks to all for your replys.
I'll hold on to my original '01 sensors for a future rebuild, and I wish you a speedy recovery from that broken leg Don.
Old Jan 16, 2009 | 11:41 AM
Bakersfield
Sorry to hear your hurt. Let me help you out, send me those sensors and I will fix them for you.
Old Sep 18, 2009 | 03:25 PM
frc99c5's Avatar
frc99c5
Hey guys, i bought my vette last week and found all the sensors were dead.. i just had a couple new tires put on today and had them take the 2 sensors out..im going to get the rears taken off soon to.. i thought about replacing the batteries myself but I suck with electronics and welding, so i wouldn't have a chance.. could i send the 4 to one of you to have them refurbished?..i dont feel like paying the $150 a piece and im finishing school so that kind of price makes me sick...Help me out guys! thanks
Old Jan 28, 2011 | 05:25 PM
thehdman's Avatar
thehdman
Don,
What do you charge to do the old ones?
Old Aug 10, 2020 | 03:32 PM
1997 C5's Avatar
1997 C5
I have 97 C5 all 4 TPMS has dead batteries. How much would you charge to rebuild mine? send me DM.
To TPMS Sensor Battery Replacement
