ABS and Traction Control light..
Old Jan 16, 2009 | 05:28 PM
Justin1889's Avatar
Justin1889
Default ABS and Traction Control light..
I know this has been gone over 100 times but every time it says to post your codes.. So here they are.
PCM- P1517H
TCS- C1226H
HVAC- B0367H
and Im sure this isnt part of it but...
Radio- V1016H
Car is a 97 Auto if that makes a difference...
Old Jan 16, 2009 | 07:14 PM
fdxpilot's Avatar
fdxpilot
PCM- P1517H
TCS- C1226H
HVAC- B0367H
Radio- V1016H
The TCS-C1226 code is your problem. The H indicates "history," meaning it was not causing the problem when you read the codes, but had been active before that. A C indicates "current." IIRC C1226 is one of your wheel speed sensors on the front wheel hub. I can't remember if its right or left. These sensors have a history of connector problems in the harness going to the wheel hub, and may be a fairly easy fix. Do a search on "wheel speed sensor" and you should get more info.
