How to test power seats
Old Jan 17, 2009 | 06:59 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default How to test power seats
I bought some sport seats that I'll be putting in my C3 and need to know how to test them. I want to test all the power functions so I can confirm everything works (I'll be selling the track assemblies when I remove them). These seats appear to be full power.
Driver's seat: There are 4 buttons on the side and the lever for tilt. The harness has a main feed that has 6 terminals and wires are being used in every terminal.
Passenger seat: Also buttons plus tilt lever. But passenger only has 3 of 6 wires used in the main connector terminal.
Can I just connect a car battery to 2 of the terminals to test the functions or is going to be harder than that?
Also, not sure if it matters but they came out of an '02.
Old Jan 18, 2009 | 12:23 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Well I just installed C6 sport seats in my C5 and all I did was hook up the red/white stripe to 12v+ and the black the neg. All functions work
Old Jan 18, 2009 | 12:58 AM
tshort's Avatar
tshort
CI 7-8 Veteran
There aren't any red/white wires on these. All the wires going into the main harness are orange, black, or black/white.
Old Jan 18, 2009 | 11:39 AM
byronhunter's Avatar
byronhunter
Do you have?
1- Power seats
2- Power seats with memory
3- Power seats with Memory and tele. stering colum
Pick one and we'll try to get a schematic for you. In the meantime, 2 orange wires get 12 volts, black goes to ground. HTH
BH
Old Jan 18, 2009 | 01:20 PM
tshort's Avatar
tshort
CI 7-8 Veteran
I got a little further last night. I put some jumper connectors on all the orange wires and got most of the functions working. I wasn't sure what to do with the black with white stripe wires though.
I was able to make the lumbar pump work but it would deflate after pressing the buttons. Is this mean something is wrong with them or does it have something to do with my crude hot-wiring?
I have no idea if the car had memory, tilt, etc. All I know is they were out of an '02.
Old Jan 18, 2009 | 03:44 PM
byronhunter
Left seat switch ^
Lumbar ^
No Telle. ^
With Telle. ^
To How to test power seats
