i want 2 do a cam upgrade and wondering should i keep my stock heads or port them or get ls2 or ls6 heads but which one is better i have a 01 c5 and would it be a good idea 2 port them or leave them alone?thanks guys
If you are upgrading the cam, buy ported heads to go along with them. There doesn't seem to be big savings porting your own, so I would just get new ones. I used ported LS6 and they work great.
get the one that is cheapest. otherwise if money is no object get ported polished AFR or PRC or TEA heads
guys sorry for all these questions but lets say i just put a cam in and leave the heads stock how much power will i be missing out on sorry for all these questions but you guys are the experts thanks in advance and sorry
It will depend on the cam. If you aren't going to replace the heads, then you may want to get a cam that is spec'd more for stock heads.
keep the duration under 280 and the lift 580 or under and your overlap 14 or above and your stock heads will love it!
Chaase is right that would really depend on the cam and the qaulity of the heads.
