2004 auto vett surges when coasting help
Old Jan 18, 2009 | 10:55 PM
a/c man's Avatar
a/c man
Default 2004 auto vett surges when coasting help
my 04 c5 surges when you let off the gas to coast pulses it is automatic i noticed it even when the car was bone stock can someone help me does anyone have the same problem?
Old Jan 19, 2009 | 09:42 AM
VinnyT's Avatar
VinnyT
What speed/RPM does this occur or is any time you let of the throttle?
I'm guessing dirty MAF sensor or bad gas. What brand gas are you using?
Old Jan 19, 2009 | 11:01 AM
spdracr39's Avatar
spdracr39
Or TPS sensor going bad?
Old Jan 19, 2009 | 11:35 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
There's a lot of things that could cause this, but I'd start with the easy stuff first. Remove the intake/filter assembly from the throttle body and check the MAF and throttle body opening. Clean the MAF with something like spray contact cleaner, and clean the mouth of the tb with a turpentine-soaked rag or something similar. If the MAF is dirty, it'll send the wrong signals to the PCM re airflow requirements. If the tb opening is dirty, the crud buildup could prevent the butterfly from closing fully.
Question: How is idle and driveability when the engine is cold?
GL!
Old Jan 19, 2009 | 01:44 PM
lucky131969's Avatar
lucky131969
I assume you discussed this with your tuner? Did they notice it during/after tuning, or when road testing after dyno?
Old Jan 20, 2009 | 08:29 AM
a/c man's Avatar
a/c man
GL!
car runs better cold
Old Jan 20, 2009 | 08:32 AM
a/c man's Avatar
a/c man
my car has always had this problem before mods it idles good.it surges at light throttel or coasting runs good when you are on the gas
Old Jan 20, 2009 | 08:36 AM
a/c man's Avatar
a/c man
im runing 93 shell or chevron it seems to do it under 50 with light gas or coasting it is a light pulse but it drives me crazy
Old Jan 20, 2009 | 08:42 AM
a/c man's Avatar
a/c man
it always had the problem i thought when we installed the procharger it would go away 20,000 miles on car.my tuner is too busy are they all like that he never answers his phone its a light pulse but it drives me crazy ill try cleaning some parts and let you guys know how it works thanks
To 2004 auto vett surges when coasting help
