Wiper problem
Old Jan 19, 2009 | 03:15 PM
biggraypig's Avatar
biggraypig
Default Wiper problem
Wipers worked erradically, and blew a couple of fuses. Thought it may have been the motor, so I milked the udders with no change except for the crap I got out of them.
Noticed today that they work fine with the steering wheel up, but when it is tilted down they don't work at all. (all I can get is one wipe on high, then they park in the ready position) Looks like I have a wire that is broken, or loosing connection, and goes to ground part of the time.
Does anyone know which wire to look for, and the area that may be causing this problem?
Thanks abunch
Old Jan 19, 2009 | 03:35 PM
lucky131969's Avatar
lucky131969
Thanks abunch
Sounds like you have half the info already. Now you just have to do some investigation in the area where the steering wheel pivots to find the problem area.
Old Jan 20, 2009 | 08:29 PM
biggraypig's Avatar
biggraypig
Just wondering what wire to look for. I don't have a schematic for the car yet.
Old Jan 20, 2009 | 09:49 PM
Bell's Avatar
Bell
Here you go. Hope this helps.
http://i714.photobucket.com/albums/w..._schematic.jpg
Old Jan 20, 2009 | 11:28 PM
c5blkvetteguy's Avatar
c5blkvetteguy
I had to replace my motor and somehow they became out of sinc. They still park in the correct spot but when the delay is on they are at the upper part of the windshield. Does anybody have a pic of the top of the wiper motor and the arm/cam that sits on the top of it?
Old Jan 20, 2009 | 11:51 PM
Choreo's Avatar
Choreo
You had me at "Milked the udders!".
Old Jan 21, 2009 | 08:15 PM
biggraypig's Avatar
biggraypig
Nothing quite like milking the udders to make for a great day.
Thanks for the schematic Bell it will help a great deal.
Old Jan 21, 2009 | 08:36 PM
7thson's Avatar
7thson
My wiper motor was ruined by being submerged in water because of clogged udders. A new motor cured erratic operation problems. Good luck. Kevin.
To Wiper problem
