Besides the bling, is there really a big differance
Old Jan 19, 2009 | 07:07 PM
tramminc's Avatar
tramminc
Default Besides the bling, is there really a big differance
with the larger brake package?
How many feet?
Old Jan 19, 2009 | 07:46 PM
Uncle John's Avatar
Uncle John
4.2 is my guess... What the hell are you talking about?????
Old Jan 19, 2009 | 07:53 PM
lucky131969's Avatar
lucky131969
Old Jan 19, 2009 | 08:04 PM
Dave Sweatt's Avatar
Dave Sweatt
I thought it was some kinda Flintstone question.
Maybe the answer is 4.2FF (Fred Feet?)
Old Jan 19, 2009 | 09:01 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
How many feet?
If I'm trying to quickly slow from 164 to 30 to make a tight 90 degree turn - I might use both feet
Old Jan 19, 2009 | 09:09 PM
MarkT 2002's Avatar
MarkT 2002
The biggest limiting factor in braking is tire adhesion. As long as you can lock up your wheels the tires are the limitation. BBKs primarily give you better cooling and therefore on a track will resist fade much better.
Some BBKs claim shorter distances but that's a combination of brake pad material, larger rotors/calipers providing better driver modulation, and front/rear bias.
Old Jan 19, 2009 | 09:12 PM
Dave concrete's Avatar
Dave concrete
How many feet?
The fact is the factory brakes on all vettes are great and perfect for daily driving ,and to answer the question on stopping distance its not just the brakes it is tires and suspension that gets a car to stop. Sure if you upgrade to a larger set up it should shorten your distance a bit but at what cost is it worth.Now if the car is going to the track this would be a different story. Change the fluid and a nice set of pads and you would have a better pedal and smooth stopping.
Old Jan 19, 2009 | 09:24 PM
Gray Ghost GS
If you're considering a BBK for performance reasons over the stock calipers, etc. - I recommend doing a few inexpensive mods first. (1) Install stainless steel brake lines; (2) Flush the brake fluid and replace with Super Blue ATE (there are other great options); (3) Install a more aggressive set of brake pads, e.g., Hawk DTC-70, Wilwood H, Carbotech XP12, etc.; and (4) Add DRM cooling ducts for the front calipers.
The traction of your tires are what actually stop the car - and the suspension setup plays a role too. These mods will significantly improve the performance of your OEM brake system. If you exceed these mods, then go for a BBK. Hope this helps.
Old Jan 19, 2009 | 09:49 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
^^ great advice!
Old Jan 19, 2009 | 11:24 PM
Purerock105's Avatar
Purerock105
Its definitely NOT worth the money for BBK's for a daily driver. Changing to Wilwoods 6/4 rotors/pads has been the most expensive mod to date on my car.
Now, I do take my car to shows, so a by-product is the bling factor, and I do take my car to the mountains(Dragon) quite regularly and I have tracked my car...but even then I replace my cross-drilled/slotted rotors with my cheap Napa rotors.
I don't have the equipment to provide real world data as far stopping distances from various speeds, but from SOTP, they certainly bring the car to a stop quicker than the stock brakes, or so it feels. I've had Goodyear GS-D3's and BFGoodrich KDW's. Both tires are outstanding, so that helps tremendously.
Old Jan 20, 2009 | 06:58 PM
japc5's Avatar
japc5
This is good 9 responses some with decent information and we still don't know what the OP was asking in the first place!!
Old Jan 20, 2009 | 07:07 PM
Targa98's Avatar
Targa98
How many feet?
I would be weary of any brake package requiring the use of more than one foot. And I would absolutely not purchase them if they require more than 2.
Old Jan 20, 2009 | 07:51 PM
tramminc's Avatar
tramminc
I was talking about the stopping distance in feet, compared to the OEM brakes.
Old Jan 20, 2009 | 09:33 PM
lucky131969
Come on now....that's what makes this forum great
Old Jan 20, 2009 | 10:44 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Do you road race the car? The larger rotors/calipers will increase the heat capacity which will provide significant brake fade reduction as well as an improved pedal feel and modulation.
With just a change in a more aggressive brake compound, you will shorten your braking distance dramatically.
Seth
Old Jan 21, 2009 | 02:59 AM
dixonk's Avatar
dixonk
St. Jude Donor '09
I switched to Baer 6S and Hawk pads on mine with 14" rotors all around and I can really feel the difference. If I put a little too much pressure to quickly on mine my stomach reminds me that I am not on stock brakes.
To Besides the bling, is there really a big differance
