belt squeal.... help
Old Jan 20, 2009 | 11:44 AM
69dodgecharger's Avatar
69dodgecharger
Default belt squeal.... help
Hi,
yesterday I noticed my zo6 was squealing so I started to investigate under the hood. I am about posative the noise is coming from the drivers side of the motor. Anyone have any ideas as to what needs to be replaced? Idler pully???? It only makes the noise around 1,700 rpm and up.
Old Jan 20, 2009 | 11:54 AM
TEXHAWK0's Avatar
TEXHAWK0
It could be belt, pulleys, tensioners, or any combination.
You just need to eliminate one at a time until you find the source.
You can mist water on the belt to see if the noise goes away.
(Do not use belt dressing as it can deteriorate the belt and/or make the noise worse)
Also look at the alignment of the crank pulley to make sure it has not moved.
Old Jan 20, 2009 | 11:55 AM
a4troy's Avatar
a4troy
i have had both tensioners go bad. the a/c had the noise in the same rpm range as yours.
Old Jan 20, 2009 | 12:53 PM
69dodgecharger
ya I was under the hood with a stethascope (spelling?) and I could not pinpoint it. Its def not the alt. It kinda seemed like it was coming from either the powersteering pump (has fluid in it) or the idler inbetween the pump and the crank.
To belt squeal.... help
