Vehicle speed sensor
Old Jan 21, 2009 | 12:56 PM
Jet-Jock's Avatar
Jet-Jock
Default Vehicle speed sensor
A friend who owns a 07 ZO6 asked me the other day where were does speed information come from. I didn't know off the top of my head.
I looked in my FSM's thinking this is probably a similar design between C5 and C6, and noted that wheel speed sensors are integrated into the hub on each wheel.
Is this also where vehicle speed information is determined from these wheel speed sensors?
Do you suppose this will be similar on next gen models?
Old Jan 21, 2009 | 01:04 PM
lucky131969's Avatar
lucky131969
My service manual set only goes up to 2005. So I can say, at least for an 05 C6, the VSS it in the differential like a C5. The wheel speed sensors are for the ABS.
Old Jan 21, 2009 | 01:38 PM
Jet-Jock's Avatar
Jet-Jock
Ok that makes sense. I looked throughout the FSMs '01 and you'd think there'd be a index marker for speed odometer, or speed sensor but nope! LOL I didn't see anything under vehicle speed sensor, so when I came across wheel speed sensor I knew it was part of the ABS but had no idea if it was like the old style systems with the speedo sensor in the transmission.
So it still is these days as well. Thanks.
Old Jan 21, 2009 | 01:41 PM
Bill Dearborn's Avatar
Bill Dearborn
The VSS is used for different purposes than the wheel speed sensors. Also trying to extract vehicle speed from the wheel sensors would be tricky as there are times when each sensor is showing a different wheel speed than any of the others. This can happen on turns, bumpy road sections, etc.
Bill
Old Jan 21, 2009 | 02:10 PM
lucky131969
The wiring diagram for the VSS is in the instrument cluster schematics:
Old Jan 21, 2009 | 02:59 PM
Jet-Jock's Avatar
Jet-Jock
I'll look tonight but there should be a corresponding schematic for the transmission side. Thanks for the schematic, that shows the signal from the PCM to the cluster. Need to see the VSS to the PCM. I bet this is in the two blue Transmission FSMs. I'll look a little more in those tonight when I get home. I should have looked there first!
The conversation got started because C6 Z drivers have such limited tires they can use. Couple manufacturers have a 345/30-19 over the OEM 325/30-19. And the question was what affect on the speedometer accuracy would there be when going to an oversized tire. We figure maybe a 1 mph delta.
Old Jan 21, 2009 | 03:42 PM
lucky131969
Nope, the replacement of the VSS is located in the service manual, under "rear drive axle", not the transmission overhaul manuals. The VSS output to the cluster, and the VSS(sensor) are on the same diagram I attached....look again. What isn't shown is the VSS output from the PCM to the ESCM.
Old Jan 21, 2009 | 04:04 PM
Jet-Jock's Avatar
Jet-Jock
Ok I'll look again in the red books for rear drive axel. What is the ESCM?
Old Jan 21, 2009 | 04:31 PM
lucky131969
Electronic Suspension Control Module
Old Jan 21, 2009 | 07:04 PM
Jet-Jock's Avatar
Jet-Jock
Thanks. Of course we haven't heard from anyone on what the change in speedometer readings would be if an oversized tire is installed.
Old Jan 21, 2009 | 09:01 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've got an '07 and I have the manuals but I'm at work right now and will have to look in the morning. The C-5's, the speed info comes from a connector on the transmission. I'm guessing its the same on the C-6, but not sure.
Old Jan 21, 2009 | 09:04 PM
lucky131969
Did you read this thread bro?
Old Jan 21, 2009 | 10:37 PM
Jet-Jock's Avatar
Jet-Jock
That's good to know that they are similar.
I wonder if swapping the OEM tire on either vehicle and going to larger size tire if that will affect the accuracy of the speedo readings.
Going from 325's to 345's, and I was curious where the sensor was at, I could only find wheel speed sensors on my '01 FSMs.
I believe the VSS is a worm gear type sensor.
Old Jan 22, 2009 | 08:03 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Nope, it's an inductance type of sensor.
BTW what is FSM?
Old Jan 22, 2009 | 12:20 PM
dgrant3830's Avatar
dgrant3830
Probably not...lol. Well, I try...lol. I was thinking he only wanted to know where the speedometer gets its info from but yeah, there's more to his question than just that.
Old Jan 22, 2009 | 12:54 PM
Jet-Jock's Avatar
Jet-Jock
BTW what is FSM?
Factory Service Manual. (Helm Inc set)
Old Jan 22, 2009 | 12:56 PM
Jet-Jock's Avatar
Jet-Jock
You got half of the question answered.
Now we figured that it would be about a 1 mph difference by going to a larger size tire. Anyone have any experience with that?
Z06 guys have limited choices on tires.
To Vehicle speed sensor
