ANOTHER IPOD QUESTION!!!!!!!!! Just one more
Old Jan 22, 2009 | 12:25 PM
soada101's Avatar
soada101
Default ANOTHER IPOD QUESTION!!!!!!!!! Just one more
first off im new :-D dont shoot me... i obviously want to hook my pod up to the vette!!!! ive looked for a while on here and just dont see a solution yet. WEELLLLL i dont want to change the head unit. i have a 03 50th anv ed and im trying to keep it as original as possible. but i want the pod i want to hook it up with aux. dont care to have control through hu. i have the 12 disk changer and i found this but dont understand.http://www.pqtsi.com/sedona/vetmp3.pdf thanks for any help!
Old Jan 22, 2009 | 12:34 PM
timemender's Avatar
timemender
Have you tried the Audio/Electronics section of this forum?
http://forums.corvetteforum.com/audio-electronics-20/
Old Jan 22, 2009 | 12:42 PM
soada101's Avatar
soada101
yeah and still nothing!!!!!!! just anyone???? out there figure anything out???
Old Jan 22, 2009 | 12:51 PM
B-ras's Avatar
B-ras
There's more than one way to do it, but the device I have is called ipod2car from Peripheral Electronics. There is lots of info about it in the audio section, as suggested above. There should be a sticky at the top of the page. Search for "ipod2car"
Old Jan 22, 2009 | 12:55 PM
soada101's Avatar
soada101
yeah i know about it.. for that price though! meh! they have this here but i cant find the relay nor can i understand the dang thing. http://www.pqtsi.com/sedona/vetmp3.pdf
Old Jan 22, 2009 | 01:01 PM
B-ras's Avatar
B-ras
I bought mine used in the parts section.
Old Jan 22, 2009 | 01:20 PM
soada101's Avatar
soada101
still cant find relay!!!!!!!!!!! doesnt come up under radio shack!
Old Jan 22, 2009 | 04:45 PM
seawolf's Avatar
seawolf
I agree with soada101. When stickees get into the hundreds of posts it is just more and more confusing and there is way too much flotsam and jetsam to go through without any sense. Can't we get a simple how to for hooking up an ipod, with and without a 12 disc changer,without a million "no I did this" or "me too's" or whatevers. And nobody need another ,"just do a search" reply. We all know that and it didn't help the first time. If you don't have aything reeally helpful to say than just don't say..... well you know. Thanks for any real insight.
Old Jan 22, 2009 | 05:03 PM
soada101's Avatar
soada101
AMEN!!!!!!!!!!!!!! is it that hard people.. thanks for what ever info though!
Old Jan 22, 2009 | 06:16 PM
byronhunter's Avatar
byronhunter
Simple enough, just unplug the rear CD changer, plug this in the place of it. Then you can feed any stereo audio source into the radio.
Old Jan 22, 2009 | 06:20 PM
soada101's Avatar
soada101
thanks for the info!!!!!!!!!!!
Old Jan 22, 2009 | 08:58 PM
Sting99's Avatar
Sting99
[QUOTE=byronhunter;1568654318]Simple enough, just unplug the rear CD changer, plug this in the place of it. Then you can feed any stereo audio source into the radio.
[/QUOT
sent you a PM , but you are on the right track with the PIE GM10 AUX
Old Jan 22, 2009 | 09:27 PM
2GOFAST's Avatar
2GOFAST
Radio Shack does not sell that part # anymore. You will need to go to an electronics dealer and get the 4 pole double relay. If you go to the store, take the diagram and someone there can help you out. However, if you can't understand the dang thing, then perhaps the plug and play options are better suited for you. It will cost more $$ but will be less difficult.
Good Luck
Old Jan 22, 2009 | 10:01 PM
johnbadami's Avatar
johnbadami
Simple hook up.
Go to Crutchfield.com. Enter your vet specs and they direct you to the right part. Pull out radio and its plug and play with the new adapter/ harness they throw in at no charge.
I ran the wire under radio bezel into console. Works through aux.
Good luck.
Old Jan 22, 2009 | 10:53 PM
Racindave77's Avatar
Racindave77
Cruising
I went to a local car electronics place, and they said there are limited choices for the C5 radio. It took 3 different harnesses to get the right plugs, but they hooked into the cd changer plug and the multi plug on the Ipod. I have some control of the Ipod...and it charges too. I believe the harnesses were from Peripheral electronics. Don't have the numbers.. hope this helps
To ANOTHER IPOD QUESTION!!!!!!!!! Just one more
