Do smooth air couplers do anything?
Old Jan 22, 2009 | 10:30 PM
glide's Avatar
glide
St. Jude Donor '13,'19
Default Do smooth air couplers do anything?
Do smooth air couplers do anything or are they just for looks?
Old Jan 22, 2009 | 10:53 PM
motogib1's Avatar
motogib1
I have one one my car and I believe that it does absolutely nothing for performance. Of course I have no data to back that up, just a guess.
Old Jan 23, 2009 | 01:22 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I have one on mine also. It was a huge gain. Not really but it should help some since the air would flow a little better. Maybe .5 hp
Old Jan 23, 2009 | 01:32 AM
glide's Avatar
glide
Every little bit helps!
Old Jan 23, 2009 | 05:28 AM
EOS 05's Avatar
EOS 05
St. Jude Donor '08
The Carbon Fiber one I have looks cool .
I had to get an aftermarket one to work with my Hurricane Intake (It is also Carbon Fiber so I figured they would look good together).
Grant
Old Jan 23, 2009 | 01:12 PM
hotwheels57's Avatar
hotwheels57
The cost usually drains your wallet somewhat. It's mostly a cosmetic improvement over the oem accordion style.
Sometimes they can cause issues with air leaks because they are more rigid whereas the accordion allowed for some misalignment. That was my experience with a silicone coupler and "Blackwing" filter when I first got my car. Some trimming is usually necessary with the silicone couplers as well.
I found the SLP design of coupler with the bump in the middle is a little more forgiving. It didn't need any trimming, either.
Old Jan 23, 2009 | 01:33 PM
lucky131969's Avatar
lucky131969
Try it out...get ready for tire shredding torque...
Old Jan 23, 2009 | 01:44 PM
YeloFevr's Avatar
YeloFevr
I was going to get a cam, but I got a smooth coupler instead...
Old Jan 23, 2009 | 01:50 PM
lucky131969
Old Jan 23, 2009 | 02:15 PM
corvettebob1's Avatar
corvettebob1
They'll make you go faster because of the weight loss.................................... ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ........................................ ................IN YOUR WALLET:rof l:
Old Jan 23, 2009 | 02:32 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Which color gives the best HP gain?
Black, Blue, Red, or Yellow
Old Jan 23, 2009 | 03:26 PM
lucky131969
Good question. I had thought about a red one, but I'm not even going to bother until I have the money for a drag pak...don't want to melt down my M/T DR's.......
Old Jan 23, 2009 | 03:27 PM
timemender's Avatar
timemender
Don't forget to upgrade to hardened rear axles if you do this smooth coupler thing.
Old Jan 23, 2009 | 03:53 PM
wildbadbill's Avatar
wildbadbill
those selling it should hang by the b____s
I understand if one wants to get a different color coupler,but to gain performance??? Because of "smoother air " stream?
How about those 'turbines" that were for sale to stir-up air for better mix with gas?
Old Jan 23, 2009 | 04:05 PM
jovette's Avatar
jovette
just cost you $ and look pretty..........added 'bling' thats about it.
Old Jan 23, 2009 | 04:31 PM
red88L98convert's Avatar
red88L98convert
every little bit is right. can't hurt, won't really help in my opinion. looks better though. again my opinion. as far as cost, that doesn't have to hurt either. my coupler came from Lowe's toilet department. 5 bucks.
Old Jan 23, 2009 | 04:52 PM
hotwheels57
Some owners of LT1 '94-96 Impala SS cars used to brag about buying their $5 FERNCO couplers from the plumbing department of their nearest home improvement store.
Then they started having erratic idle issues. Those couplers are made of elastomeric polyvinyl chloride (PVC).
If you elect to use the PVC couplings from aisle #8, be sure you check them regularly for evidence of cracks.
They were not intended to be used in the hot confines of a C5 engine compartment...
To Do smooth air couplers do anything?
Old Jan 23, 2009 | 05:05 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
The stock accordian-style coupler is made that way for a reason. Its designed to flex and prevents the coupler from possibly separating from the TB on hard acceleration or deceleration. It is not a restriction to air flow.
Old Jan 23, 2009 | 05:06 PM
David426's Avatar
David426
they add about the same hp as a cat back exhaust system
Old Jan 23, 2009 | 05:49 PM
red88L98convert
ahhh ha!! they were designed for the hot confines of the C5...not the Impala SS cars.
Mine has lasted for five years and counting.
