I'm dripping from the rear
Old Jan 23, 2009 | 05:27 PM
lp2k's Avatar
lp2k
Default I'm dripping from the rear
Hi everyone, like the title says, I am dripping some fluid that looks to have appeared a week ago, it is brown like engine oil, but it is comming from the rear driver side of the car.
Could this be automatic fluid? if so, shouldn't it be red?
Could it be differential fluid? if so, is it brown like engine oil?
What are my options here? I do not have lift access so I will have to go to a shop to get the work done (the stealership)
Well thank you all, and I will be more than happy to post pics of the fluid drops in the garage.
Leo
Old Jan 23, 2009 | 05:31 PM
mickey_7106's Avatar
mickey_7106
Leo
need a little more info...where in rear is it dripping from?
Old Jan 23, 2009 | 05:33 PM
aleadfoot's Avatar
aleadfoot
Probably the left diff seal a common problem. You have to get under it to verify as sometimes there is an overflow condition that develops and causes purge of fluid out of the top. Check around the shaft you will know.
Old Jan 23, 2009 | 05:49 PM
bobby777's Avatar
bobby777
dripping from your rear-end--I suggest a plug or maybe a trip to your drug store-- its a rear seal and a trip to your mechanic
Old Jan 23, 2009 | 08:27 PM
lp2k's Avatar
lp2k
Yes, it was my attempt at humor and thanks for getting it
I was figuring it was a differential seal, differential fluid looks like motor oil? Sorry no diff fluid lying around here
Oh yea, I do not race/track or autocross my car, just Point A to Point B and the occasional burst from 40-100mph
Old Jan 23, 2009 | 10:23 PM
argonaut's Avatar
argonaut
Yes gear oil in the differential will look just like motor oil, only difference is its a little thicker (but you wouldn't be able to tell that from a few drips). It is most likely the seal where the axle mates into the differential. The seal will cost you about $25 at the dealer...its the install that will kill you. They need to drop the whole rear cradle out of the car and remove the side of the differential. I did it myself...not too hard. But I'm sure the dealer would charge you several hundred for the job.
Old Jan 24, 2009 | 08:25 AM
minitech's Avatar
minitech
The diet pill Alli will do that. Too much oil intake leads to a brown oily dripping from the rear. Solution is to lower the oil intake (And that is how the pill ends up working.)
Old Jan 24, 2009 | 08:40 AM
ecoman's Avatar
ecoman
Sounds like personal problem
Old Jan 24, 2009 | 08:57 AM
lp2k's Avatar
lp2k
Is there anyway I can view someone who has dropped the rear out of a C5 and done this before?
would this link work
http://www.cajundude.com/outputshaftseal.htm
Old Jan 24, 2009 | 08:59 AM
lp2k's Avatar
lp2k
Well it is from the driver rear end, I didnt see anything when I am on my knees looking underneath the car. I only notice it when I went to sweep the garage.
Old Jan 24, 2009 | 09:00 AM
lp2k's Avatar
lp2k
I do not follow?
Old Jan 24, 2009 | 09:41 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
It is usually the driver's side rear diff cover that leaks. The fix is to pull it apart and use the sealer on the mating surfaces. My 02 was leaking with only 9,000 miles on it. Did it in my garage on the lift. Takes about 3 hours if you know what you are doing. Re-fill the rear end with GM synthetic and one 4 oz bottle of GM posi lube.
If you can't take this on yourself make sure whoever you hire has a proven track record. Too many stories of this repair having to be done over and over again. Good luck
Old Jan 24, 2009 | 10:21 AM
TEXHAWK0's Avatar
TEXHAWK0
Look at the seal where the half shaft goes into the differential.
Old Jan 24, 2009 | 11:30 AM
kingrobby25's Avatar
kingrobby25
When I bought my car everything looked good, drove it home to Seattle,WA from Palmdale,CA.......went about changing all the fluids a few days later and noticed the differential drain plug was not even finger tight! It was only screwed in about 3 threads worth! Imagine if it came undone on the way home somewhere along the 1,100mile journey. So in addition to checking what everyone else has already told you to check, I would also check the drain plug for tightness.
Old Jan 24, 2009 | 01:49 PM
Jamn's Avatar
Jamn
Had this problem on my 01. After the dealer installed a new seal it would only hold for a few months. It took about three tries before it stopped leaking for any significant length of time.
Old Jan 24, 2009 | 02:51 PM
ecoman's Avatar
ecoman
Old Jan 24, 2009 | 04:43 PM
lp2k's Avatar
lp2k
Can anyone ellaborate on the link I posted if that is the seal that needs to be fixed? How many hours of labor? Anyone have some help tips
To I'm dripping from the rear
Old Jan 24, 2009 | 05:02 PM
Vette19's Avatar
Vette19
The link looks right. Not a bad repair to make! Look at it first and make sure that is what's leaking.
Old Jan 26, 2009 | 01:56 AM
Jamn's Avatar
Jamn
It cost me $500.00 at the dealer to replace the seal.
Old Jan 26, 2009 | 07:46 AM
Jetts4u2's Avatar
Jetts4u2
My 99 A4 was always damp in the middle in front of the axle, light leak for a lllooonnnnggg time. Kept looking, finally, tightened the tranny pan bolts, leak stopped.
