Clutch Disc Question
Old Jan 24, 2009 | 08:35 AM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Default Clutch Disc Question
Replacing the clutch slave cylinder on my son's LS1 04 GTO. The car has 45,000 miles. Pressure plate, disc and flywheel look good. Clutch disc is .340" thick.
Anyone know the thickness of a new disc? If the clutch is good for another 40,000 iles..most likely will put off replacing. If is less than 50% of it's life, most likely will replace. Thanks
Mark
Old Jan 24, 2009 | 01:42 PM
nastymant's Avatar
nastymant
i'm in the middle of swapping mine...my 98 c5 with 90,000 measures an average of .330 thick...I bought a used ls7 with 13K miles and it is about .370 thick
Old Jan 25, 2009 | 12:20 PM
mbeeman350's Avatar
mbeeman350
Did some more research, seems most new discs are .360"-.370" for LS cars w/6 speeds. So with .340" on our disc, we put the car back together with the existing clutch. Save that $500 for another day. Finished the car last night, runs like it should. One note, I would recommend a remote bleeder for this and other GM cars with slave cylinders. Has to make bleedig easier !!!
Mark
To Clutch Disc Question
