Balancer replacement recommendations
Old Jan 25, 2009 | 04:22 PM
Slider-01's Avatar
Slider-01
Default Balancer replacement recommendations
I'm going to have to replace the balancer on my 97. . .any recommendations on which balancer go to with? I have heard the Powerbond is ok and also the SLP. Also see that Mid America carries a balancer.
Any recommendations arre welcome.
Old Jan 25, 2009 | 06:29 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
I recommend the SLP or Powerbond
Old Jan 25, 2009 | 07:12 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Both ASP and SLP are quality pieces. You can't go wrong with either.
ASP Underdrive Pulley
Seth
Old Jan 25, 2009 | 08:50 PM
Slider-01's Avatar
Slider-01
Seth
I assume if I decide to go with an Underdrive pulley the AC and the main belts are larger than stock; Right?
Any stock numbers on the belts?
Thanks, great information. . .
Old Jan 25, 2009 | 08:53 PM
0HinsonSuperCars
Former Vendor
It's all right there in that link
- Includes a new Balancer Bolt.
- Requires a new Serpentine Belt & A/C Belt.
Gates Serpentine Belt
Part # 25060772
Gates A/C Belt
Part # 25040410
Old Jan 25, 2009 | 10:10 PM
Slider-01's Avatar
Slider-01
Part # 25060772
Gates A/C Belt
Part # 25040410
thanks, Seth. Went to the link. . . .
While I am doing this, should I replace anything else?
Old Jan 25, 2009 | 11:01 PM
0HinsonSuperCars
Former Vendor
No, that's it.
Old Jan 26, 2009 | 01:08 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
If you don't have an upgraded cam and desire one, this would be the time to do that. You'll be doing much of the work involved in a cam swap. That will snowball into hardened pushrods, valvesprings and a tune. Rocker arms wouldn't be a bad idea while you're doing a cam. Hello income tax refund!
Old Jan 26, 2009 | 01:29 PM
98vettedave's Avatar
98vettedave
Really not that much more money involved.Buy a good use cam,if all the other parts are new,then the cost should be under $550.
I am presently running a TCI balancer,everything TCI makes is first rate quality.
Old Jan 26, 2009 | 01:58 PM
Itallian33's Avatar
Itallian33
I just replaced mine on my car. If it is moving around i would replace the seals on the Timing cover, a couple of dollars and they are worn because of the balancer.
Old Jan 27, 2009 | 10:21 AM
Jims79's Avatar
Jims79
Part # 25060772
Gates A/C Belt
Part # 25040410
Does the SLP pulley also require a smaller belt?
Old Jan 27, 2009 | 11:24 AM
corvettebob1's Avatar
corvettebob1
Regardless which balancer you use, PIN that puppy to the crank so you won't be tearing it down again when it slips.
Old Jan 27, 2009 | 04:56 PM
road dog's Avatar
road dog
I say fluidampner read about it before you decide on a powerbond or some other one a superior product
Old Jan 27, 2009 | 04:57 PM
0HinsonSuperCars
Former Vendor
Yes
Old Jan 28, 2009 | 09:17 AM
jimcork1's Avatar
jimcork1
I would replace the belt tensioner and idler pulleys. I just changed mine out and what a pain. If you have it opened up and can get to them change them out. Also GM has a new design for the ac tensioner that fails early. The pivot bearing shielding has been changed as a result of the earlier design prematurely wearing resulting in pulley misalignment..
Remember
pointy end goes to the front
fire comes out of the back
and always put the rubber thinginges down first.
Attain proper position
Hand grips raise
Trigger squeeze
And don't mess with the red guarded switches.
Class of 71-04
Old Jan 28, 2009 | 09:36 AM
Slider-01's Avatar
Slider-01
jimcork1
Hand grips raise
Trigger squeeze
The above sounds very familar. . . .
I flew F-100, F-4, F-15, and F-18s. . . .
Thanks for all the great responses to this. I think I am going with the Powerbond since I can buy it locally.
Great information, thanks to all.
To Balancer replacement recommendations
