sounds like a knock
Old Jan 25, 2009 | 05:09 PM
drtyTshrt's Avatar
drtyTshrt
Default sounds like a knock
2003 LS1 12500miles. I hear what sounds like a knock coming from the passenger side of the motor when I first crank. The noise goes away in short time after driving I want to say it is the belt tensioner but I am not sure anybody have any hints? Oil is good pressure is good and oil temp barely reaches 200 degrees while driving.
Old Jan 25, 2009 | 05:49 PM
seawolf's Avatar
seawolf
One of the very, very rare times I will tell someone to do a search. It sounds like you have the typical LS1 "WTF is that?" I believe you will hear that it is normal and not to worry.
Old Jan 25, 2009 | 05:57 PM
lucky131969's Avatar
lucky131969
A "knock" is not a typical description for anything external, so you may want to redefine your terms. You may have a tapping coming from a lazy lifter. Guess you'll just have to stick your head under the hood and try to isolate the noise.....everyone will just be guessing until you do.
Old Jan 26, 2009 | 05:14 PM
drtyTshrt's Avatar
drtyTshrt
I would say that it is more of a tapping than a knock and it is loudest on first crank cold engine. It does not last long but is loud enough to make me wonder WTF. How long would the lazy lifter tap after the engine is warm?
Old Jan 26, 2009 | 06:24 PM
David426's Avatar
David426
sounds like a piston slap issue.. Very common and very normal http://pistonslap.com/
Old Jan 26, 2009 | 07:26 PM
drtyTshrt's Avatar
drtyTshrt
Very interesting!!! I have not heard of this before. Mine does not sound as bad as a diesel but it could compare. I also have soot in one of my tail pipes.
Old Jan 31, 2009 | 12:16 PM
David426's Avatar
David426
piston slap is very normal and that link is a little exageratted in my opinion.. Its just the nature of the beast and is more annoying/embarrassing than anything else... My 99 c5 had it and it was just something you had to get used to.. I did a lot of searching to find more info on this piston slap.. Theres never been any engine failures due to this.. Many folks have 0ver 150k miles with no problems.. Do a search on this forum. Type in piston slap.. It will put you at ease... It is annoying and bothered me for a long time.. My 02 z06 does not have this issue..
Old Jan 31, 2009 | 12:44 PM
VinnyT's Avatar
VinnyT
Old Jan 31, 2009 | 03:06 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
This is real basic...if its tap from the top end, then its a lifter. If its a knock from the bottom end, then its either the reported piston slap or a rod bearing.
Old Jan 31, 2009 | 05:45 PM
Chevy-SS's Avatar
Chevy-SS
http://forums.corvetteforum.com/c5-g...hing-help.html
There's a good thread on piston slap - which it sounds like you have............
To sounds like a knock
