HELP Static
Old Jan 25, 2009 | 09:52 PM
deputy2u's Avatar
deputy2u
Default HELP Static
i am now having static in my add-on CD player and my add-on XM Sat radio..can anyone suggest a fix? might it be another ground issue?
thanks
Old Jan 26, 2009 | 12:45 PM
deputy2u's Avatar
deputy2u
Default static
no one knows the answer to this problem?
Old Jan 26, 2009 | 01:06 PM
byronhunter's Avatar
byronhunter
It might be, what are you using to feed the audio to the radio?
Old Jan 27, 2009 | 02:52 AM
deputy2u's Avatar
deputy2u
thanks Byron, i am using an fm modulator rather than a direct line..this may be it?
joe
Old Jan 27, 2009 | 11:19 AM
byronhunter
Try this, No static and lots better sound.
Old Jan 27, 2009 | 11:59 AM
deputy2u's Avatar
deputy2u
Default static
thanks, Byron, i will give it a try ... any electronics outlet? or only at a dealer since it is labeled GM10?
joe
Old Jan 27, 2009 | 01:14 PM
byronhunter
I never seen it local, I had to order on line. Google "GM10-AUX". Sometimes on big auction site. IMPORTANT, it plugs in, inthe place of the factory CD changer in the back. If you don't have the cable to the back, it is expensive. Short time ago, someone on this forum had the adapter and cable for sale.
http://forums.corvetteforum.com/c5-p...light=gm10-aux
Old Jan 27, 2009 | 01:24 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
thanks
If it were a ground issue, usually it would come out as a "whine" in the radio. You should always ground all components ON THE SAME SCREW/GROUND POINT. (avoid ground loop).
The suggested device is what everyone runs so you should be good.
Old Jan 27, 2009 | 03:04 PM
deputy2u's Avatar
deputy2u
Default static
thanks for the help, guys, i appreciate it..
joe
To HELP Static
