I just started having thi s happen today TCU -1291 HC. Says it a brake switch. Is it the one on the pedal? Never surfaced before. Am willing to gance but the brake pedal has 2 switches which one. They are both a little loose in my opinion
Danny
1. With the brake pedal depressed, insert the stop lamp/cruise control switch into the retainer until the switch body seats in the retainer. You will hear the CLICKS as the threaded portion of the switch is pushed through the retainer.
2. Slowly pull the brake pedal fully rearward against the stop until you no longer hear the CLICK sound . The switch will be moved in the retainer providing proper adjustment.
