97 knock
Old Jan 27, 2009 | 04:34 PM
c-5-steve's Avatar
c-5-steve
Default 97 knock
Well brought our 97 coupe home sunday it has 27,000 miles on it. The wife drove it home so I could see it rolling down the road. Trip was 150 miles. everything worked fine but when we got home and my wife was setting in the driveway I noticed a knocking noise. Not a lifter tick (I know what that sounds like) It was kind of a dull kind of knock. I'm thinking (rod). But when she put in park or nutural the noise quit. I started it the next afternoon and let it run for say 10 min. But I couldn't get it to make any noise. I emailed the previous owner to ask him about it. He told me he took it in and was told it was exhaust noise and that it is common for C5s and there wasn't anything they could do about it. Is this true? It doesn't sound like any exhaust noise I ever heard. Our 2000 C5 never made any noise. What do you think?
Old Jan 27, 2009 | 04:45 PM
jovette's Avatar
jovette
Assume it's an automatic, since you referance park/neutral. What you describe, is a knock when @ idle, but under transmission load.....hence the no knock when in neutral/park situation.
When it was making the knocking noise, did it speed up with increase in engine speed and was it consistant with the increased engine speed?
Suggest you whip out the trusty old engine stethoscope the next time you hear the knock and open the hood and try to loccate isolate same.
Good luck
Old Jan 27, 2009 | 04:53 PM
c-5-steve's Avatar
c-5-steve
Good luck
yes A4. Didn't have her break torque it. But it sounded timed with the engine at idle spd.
Old Jan 28, 2009 | 02:04 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
If you have a video camera take a video so we can hear it. It can be many many things other than a rod.
Old Jan 28, 2009 | 04:42 PM
c-5-steve's Avatar
c-5-steve
I listened to the knocking sounds from your post but it dosen't sound like any of those. it's more of a dull sound that seems like it's coming from deep in the engine.
I talked to 2 diffrent people at work and the both said trhe same thing. "cracked flywheel" of course a flex plate in a automatic. What do you think about that? Is this common?
I have pulled the battery it was no good. I didn't want it to freeze and crack in the car. I won't be running it until spring now, it's too nasty in Mich. in the winter. I will let everyone know what is going on when I find out.
Old Jan 28, 2009 | 05:06 PM
dmiz0420's Avatar
dmiz0420
Originally Posted by 8VETTE7
There have been a couple of threads about knocking noises of late. One posted a link to a site that talks about piston slap and has a recording of what that sounds like. The site was
http://pistonslap.com/
A second thread was about a spun rod bearing . Here's the video and sound track of his engine:
http://www.youtube.com/watch?v=gRSrUQudaP0
The thread about this persons problem is here:
http://forums.corvetteforum.com/c5-t...d-bearing.html
Check them out and compare to the noise you are hearing.
Of course there are othger things that it may be as well like broken exhaust parts that are vibrating when under load etc.
Keep us posted..........
Are the pictures on piston slap. com of the pistons withthe valve marks in them supposed to be caused by piston slap?
Aren't thaose cause by missing a shift and over revving? I just can't imagine piston slap being so bad on 4 cylinders that it leaves valve reliefs on 3.
Congrats on the 97 Steve! They are always fun to figure out what's going on with the first model year.
Old Jan 28, 2009 | 05:21 PM
BUGZ's Avatar
BUGZ
Old Jan 29, 2009 | 05:15 PM
c-5-steve's Avatar
c-5-steve
I wouldn't call it fun. It actually is stressing me out, thinking I got ripped off.
Old Jan 29, 2009 | 08:04 PM
NC99's Avatar
NC99
Definitely the flywheel.
Old Jan 31, 2009 | 06:28 AM
c-5-steve's Avatar
c-5-steve
Tell me why u believe it's the flywheel/flex plate. I hope your right, that would be much better than a bad engine.
Is it a tough job on a c5 w/a4 to change myself? What's the cost of a new flex plate?
thanks for the input.
To 97 knock
