Something broke...
Old Jan 27, 2009 | 07:26 PM
trappg's Avatar
trappg
6th Gear
Default Something broke...
Stock 2003 Z06 35,000 miles... Was on my way home today when when traffic stopped several hundred yards in front of me. As I slowed, I down-shifted to 3rd, then to 2nd, popping the throttle to match revs. When I popped into 2nd, something let loose. Made an awful clatter. Luckily I was able to pull right into my neighborhood when I finally shut down. I was hopping it blew the top of a plug out but I'm afriad it's worse than that. It makes a very loud clatter up in the head area. To just turn the engine over sounds fine but once it tries to fire it clatters louldly. From what I've seen on the forum, maybe a broken rocker??? Any advice greatly appreciated.
Old Jan 27, 2009 | 08:26 PM
keliente's Avatar
keliente
No way to find out other than getting a few tools and doing a little exploring. I would pull the valvecovers first, that will only take 10 minutes and you will be able to determine if it is a spring/rocker/pushrod/etc, or if you will need to dig a little deeper.
Old Jan 27, 2009 | 11:41 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree totally. If its not apparent with the rockers, do a compression test. Do not try to run it again till you've done all due diligence with it.
Old Jan 28, 2009 | 12:39 AM
lucky131969's Avatar
lucky131969
Old Jan 28, 2009 | 11:56 AM
Nightstick's Avatar
Nightstick
Ouch. Good luck with it.
Old Jan 29, 2009 | 12:43 AM
99FewteRC5's Avatar
99FewteRC5
more than likely a valve spring broke
Old Jan 29, 2009 | 09:58 AM
11SECSS's Avatar
11SECSS
my thoughts as well...
Old Feb 3, 2009 | 08:35 PM
trappg's Avatar
trappg
6th Gear
Yep, broken intake valve spring. I wonder what the chances of there being more damage down in the cylinder? Is there the possibility of the piston crashing up into that valve causing major damage to piston and cylinder wall? Outide of removing the head is there a way to tell if there is a broken valve down in that cylinder? Great group of knowledge here, thanks to all!
Old Feb 3, 2009 | 08:40 PM
ColeTrain'sC5's Avatar
ColeTrain'sC5
ouch, good time to upgrade. You could replace just the one but i'd replace ALL of them. One fails they all could just as easily do the same
Old Feb 3, 2009 | 09:31 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Probably nicked the piston, but doubtful you hurt it, but it's more possible to bend a valve. You'll know when you're changing the valve springs if you do it the way most do with compressed air in the cylinder. If you hurt the valve, you'll hear a bunch of air running into the intake or exhaust, depending on which spring you broke.
Old Feb 4, 2009 | 01:08 PM
dgrant3830's Avatar
dgrant3830
Excellent pictures! The only way you'll know about the piston is to pull the head. Might as well to be sure. No sense in doing the job half-way on a hope. I think of the old saying, better safe than sorry.
Old Feb 4, 2009 | 11:38 PM
rebelheart's Avatar
rebelheart
I would replace the valve springs on that cylinder and do a compression/air test.If it seemed ok ,replace the rest of the springs ,button her up and ride!
Old Feb 5, 2009 | 08:12 AM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Are those stock springs? A vettes with only 35,000 on it and you snapped one like that? Is this typical or heard of? Man that would worry the hell out of me if its that easy to snap something. Especially cause you weren't romping on it. How are you driving habits with it? Do you have any power adders? Are you the original owner?
Old Feb 5, 2009 | 10:13 AM
jovette's Avatar
jovette
If you really wanted to, suppose you could get / borrow one of those small cameras with a light on a flexible tube that you could insert into the spark plug hole and look around to see if there was any visable damage to piston. But I still agree that if the cylinder holds compression, you should be good to go.
Old Feb 5, 2009 | 10:38 AM
dgrant3830's Avatar
dgrant3830
Excellent idea. My concern is if there is a nick, cut or whatever on top of the piston, it'll still pressurize and run, but any damage, it would create a hot spot therefore resulting in future problems of a major magnitude. It would be nice if there was zero damage in there but the OP needs to look, one way or another.
Old Feb 5, 2009 | 12:02 PM
'02magredZ51's Avatar
'02magredZ51
Not to burst your bubble... but I'd pull the head and take a good look at that lifter too. By the marks on the bottom of the spring coils it looks like it was binding a little. As XtremeVette said... there's no reason for a stock, low mileage, adult driven, Z06 to break a spring like that.
Old Feb 5, 2009 | 12:14 PM
rebelheart's Avatar
rebelheart
pistons are very tough,far more likely to damage a valve than a piston,if the valve is ok more than likely the piston is fine.Actually is not uncommon at all for these springs to pop!
To Something broke...
Old Feb 5, 2009 | 12:34 PM
XtremeVette
really? damn....I am not that knowledgeable when it comes to the inner workings of the motor. I know the basics...that is about it. If it is that easy for a performance car such as the Z06 model of the vette Iam guessing it could apply to any pushrod engine car. How come by something so little (the spring) that it can cause that kind of damage. Let me rephrase that...how come there are no real safeguards when it comes to retainers or springs that would prevent a breakage or pop off of a nut or retainer seeing that the result is so detrimental to the engine? Seems like a little nut, retainer or spring that goes "pop" can cost you in excess of $3000 to get your motor redone? hmmmmm am I understanding this all correct? or is this really very uncommon and is why manufactures have no safeguard? Do they figure the stuff is built strong enough? Sorry for all the questions....iam a nub'e when it comes to engines and their internals.
Old Feb 5, 2009 | 12:44 PM
OhioC5's Avatar
OhioC5
I want to know whats keeping that valve from falling into the motor.
Old Feb 5, 2009 | 01:18 PM
slothy's Avatar
slothy
can the valve drop complete in the motor? looks quite far down in picture.
