I started my car this morning and I noticed that something is not right from the sound of it, so I thought it is cold and I went back home and let it worm up for a bit. After 5-10 minutes after a quick breakfast I have come back ready to drive to work and what the heck the sound got worse. I looked at the gages and became speechless. The freaking oil pressure was 0 (I have had this problem before but supposedly dealer fixed it for me, well guess not). So I called dealer and they picked up my car, I must say pretty quickly I only waited 15 minutes for the tow track. Anyway after mechanic started the car and heard that noise he said that two things are wrong 1 Oil pump and 2 he does not know for sure but something could have been damaged in the engine from running without oil. Hence he will be taking apart my engine at least to some part of visibility of what could have gone wrong if any.
Do you have any idias what could go wrong from runing up to 10 minutes without oil?
The engine has hydraulic lifters and cam - without they wear out much faster. Besides that lack of oil pressure could easily cause you to spin a bearing or other bottom end problems. My solutions was to install an ARE modified LS6 oil pump. Plenty of oil pressure now!
The oil pump pressure relief valve is most likely stuck open. Do a search, and you should find quite a few others that had the same problem.
Mine was bad enough to warrant a replacement engine. Total time running w/out pressure for me was a matter of minutes, so make sure they check the engine out. If there's damage down low, there is most definitely up top.
In 2000 some had a bad run of oil pumps. The clearances were not correct. This time make sure that they replace the oil pump with the new part number.
I would send the new pump to ARE, if I was you, to get them to blueprint it for you. Of course there would be a waranty consideration here however that is what i did for my engine.
Yikes, I hope all goes well on this one. Did you check the gauges when you first started it? You need to get you story straight on this one with the dealer. Good luck!
Well I just talked to my dealer and he said that they will change the oil pump (he actually mentioned some part number), and that engine should be ok, but he will be able to tell for sure sometime tomorrow after they put oil pump together.
vetterdstr, I see that you are all ready for the Saturday, you even mounted camera already :). Well too bad for :(me but hopefully next time or who knows if my dealer will give me a go tomorrow then I can still make it.
"I started my car this morning and I noticed that something is not right from the sound of it, so I thought it is cold and I went back home and let it worm up for a bit. After 5-10 minutes after a quick breakfast I have come back ready to drive to work and what the heck the sound got worse."
From what you say here, I would make them give me a new engine! No oil presure for 10 minutes is just plain scarry. :eek:
Supercharged has a good point about the "Check Gauges" light. Also, I read somewhere that the engine was supposed to shut itself off if oil pressure drops below 2 psi.
We went through this same dialogue when my pump when bad this last summer.
Will the engine shut itself down with zero pressure, yes.
Will the check gauges warning come on in the HUD as well as the panel, yes. It will because your gauge is reading at ZERO.
Is there probably a 'little' oil pressure in there? yes.
BUT, until you experience this, the NOISE your engine is making as the lifters pop along without any oil, can you understand what is going on. If the engine is making NOISE, then something is wrong and there is probably damage. If he says the engine was making noise, then there is a problem.
Demand that they, at a minimum, pull some caps and look at the main bearings and journals. Mine were trashed. And, if there is damage down there, then there is damage up top. A good tech should do this during the pump swap, but make sure you specify.
I feel your pain. It took a lot of leverage from a lot of really good members here to get my issue resolved to my satisfaction.
Well, to be honest I did not noticed any gages warnings when I started the car, so I am not sure if the oil pressure was 0 at the begining or was it just low oil presure and then droped to 0? Though my dealer told me that they will open engine and that they will look for problems there. They supposed to start workingn on my car today so maybe by the end of tomorrow I will know some info if it is ok or not.
I had the same problem on a 2K. Oil press. went to zero during cruise. DIC gave a NO OIL PRESSURE message but did not shut down, then got HIGH OIL TEMP., then REDUCE ENGINE RPM. Dealer installed new oil pump and returned to me but the pressure was way low (internal damage) Drove back in and the motor literally locked up while pulling into dealership and rolled up to the service writer. Got a new crate motor in 8 days.
I was told that the orig. problem on the pump was not the check / relief valve but that it actually froze mechanically. The motor sounded like it was ready for hospice upon return, the damage was already done. It was one terminally ill LS1.
I had the same problem with the "no oil pressure" at start up.
Oil pressure relief valve was stuck open with red loctite from the factory (or where ever they build the engines).
Because the dealer took 3 attemps to fix (even though we were telling them oil pump) I needed a complete rebuild. My #8 main was bad. The #8 is the furthers upstream from the oil pump.
If they aren't going to disassemble the engine to check the bearings, have them pull the oil pans to check for burnt oil.
If they do disassemble have them check the piston to cylinder wall clearance. Some engines got small pistons and cause oil consumtion and piston slap.
GM replaced my rings & pistons because my p/c was double the tollerance.
