Cam Swap??
Old Jan 30, 2009 | 09:13 AM
jrbrown1963's Avatar
jrbrown1963
2nd Gear
Default Cam Swap??
Has anyone ever put a Z06 cam in a 1999 corvette?? If so how difficult is this to do?
Old Jan 30, 2009 | 09:35 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
While I'm sure there are some that have done it, I would guess most would put in something a little stronger than a stock Z06 cam.
It is not too much work for the mechanically inclined with proper tools or take it to a shop for outpatient surgery.
But, again, if you're gonna do the work, you may as well put something a little stronger in.
Old Jan 30, 2009 | 10:08 AM
11SECSS's Avatar
11SECSS
While its not THAT hard, it is time consuming and for the time and money you might as well put a bigger stick in it... however if you are hell bent on a Z cam.. I have my stock one out of my 01 that I'll sell...
Old Jan 30, 2009 | 10:23 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
If you are going to spend the labor I would suggest something a little bigger.
Old Jan 30, 2009 | 10:36 AM
Bull_in_a_china_shop's Avatar
Old Jan 30, 2009 | 10:59 AM
D C's Avatar
D C
USMC (retired)
And there you have, the forum has spoken . Put a bigger stick in that thing.
Old Jan 30, 2009 | 12:10 PM
OhioC5's Avatar
OhioC5
I would at least get into the 224 range If your going to take the time to do it.
Old Jan 30, 2009 | 12:11 PM
iced98lx's Avatar
iced98lx
Werd! Did it in the garage on jackstands - it wasn't that bad of an experiance
Old Jan 30, 2009 | 03:36 PM
dmiz0420's Avatar
dmiz0420
I would think you would want new valvesprings
I think those are perimeter bolt heads, I would go with the 243's or new 799's (same thing)
Old Jan 30, 2009 | 04:31 PM
jovette's Avatar
jovette
Believe with the lift of the '02 and later Z06 OEM camshaft, you MUST use different springs, and may have to if you use the smaller '01 Z06 bump stick. Might want to check if new push rod also are recommended.
Swapping your OEM '99 camshaft for an '02 or later Z06 camshaft might be OK, if you can get the camshaft for little or nothing and if you can do the work yourself or with buddies, so you don't have any labor expense.
Old Jan 30, 2009 | 06:13 PM
The Wrench's Avatar
The Wrench
The stock lS1 cam has a 19.7mm base circle.
The '02-'04 Z06 cam has a 19.0mm base circle.
This will cause the lifter piston to have to compensate and rise 0.7mm in the lifter. This is only 0.028", and usually causes no issue. But GM thought it might, so they made the Z06 valve stems longer to keep the lifter pistons centered.
Just another reason to go with a good aftermarket cam.
DG
Old Jan 30, 2009 | 07:28 PM
sami85L98's Avatar
sami85L98
Consider Lpe GT2-3 cam as its basically hairline bigger than Z06 cam, and prolly no tune needed, LS6 springs and GT2-3 cam and u r good to go, anolther 20 hp and flat torque curve. GT2-3 207/220 .578/.580 and 118.5 LSA.
Old Jan 30, 2009 | 08:06 PM
jrbrown1963
2nd Gear
what cam would you recomed for a 1999 c5corvette. I have longtubeheaders and Borla exhaust z06intake; blackwing air intakefilter. 6speedtranmission.
Old Jan 31, 2009 | 06:44 AM
bradenW's Avatar
bradenW
What power levels are you trying to reach? Do you drag race or auto-x? What kind of driveability do you want?
Old Jan 31, 2009 | 08:29 AM
slvr76's Avatar
slvr76
These are all excellent questions. There is just not going to be one cam profile that fits all users. You need to honestly ask yourself what goals you have for the car, both now and in the future. Also how important is it to you to maintain stock like driveability? Big cams and good heads make great power, but you will lose some of the easy to drive creature comforts of your car. If you increase power too much you will need an aftermarket clutch, bigger injectors, stronger valvetrain components, etc... Once you decide what you want from the car there are many people here who can help point you in the right direction
To Cam Swap??
